VW Transporter T6 TPMS Reset
skizauchensee.com
New Member
Austria
HC706237 (NRRT)
Please could anyone provide VCDS information in resetting the TPMS on a 2017 VW Transporter T6.
The media player does not have the "Car" button to allow a reset.
There is no reset button fitted and there are no steering controls to access the "Car" settings.
I have followed the previously posted settings but the latest software differs slightly from that posted.
Trying to reset the TPMS system using the latest software just tells me that a reset is not possible as there is a "Code Error"
Any help would be appreciated.
Thank you for your time
Please post an Auto-Scan so that people can see what control modules this vehicle is equipped with and how they are configured.
skizauchensee.com
New Member
Austria
HC706237 (NRRT)
Below is the Auto Scan information for the car:
Monday,28,November,2016,15:53:50:30800
VCDS Version: 16.8.4.2 (x64)
Data version: 20161129 DS267.0
VIN: WV2ZZZ7HZHH063537   License Plate: STRIMS
Mileage: 3570km-2218mi   Repair Order:
Chassis Type: 7H (7E0)
Scan: 01 03 04 08 09 10 15 17 18 19 22 25 5F 61 6E 0B
VIN: WV2ZZZ7HZHH063537   Mileage: 3570km-2218miles
33-Flux Capacitor -- Status: Malfunction 0010
6E-Ctrl Head Roof -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXHA)       Labels: 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KK    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 3034
   Revision: 23002001
   Coding: 0019401C432601090000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KK 004002
   ROD: N/A
   VCID: 0009C5BE9B7B5342C9-8054
No ASAM data for: "EV_ECM20TDI03004L906056KK" (VN75)
Readiness: N/A
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 42686000000261
   Coding: 347E8098256884812C7A0179A4892193780000
   Shop #: WSC 02739 790 50316
   ROD: EV_Brake1ESCCONTIVN75XGP2_011_VN35.rod
   VCID: 3F8B0642A605ECBAF0-806A
0397 - TPMS Warning
          C102D F0 [137] - Pressure Loss
                    Reset counter: 47
                    Mileage: 1453 km
                    Date: 2016.09.20
                    Time: 15:08:53
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Component: LENKW.SENSOR  H07 0070
   Serial number: 11091613470216
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF5BB46E18F25B2BB-802A
Address 08: Auto HVAC (J301)       Labels: 7E5-907-047.clb
   Part No SW: 7E0 907 047 AJ    HW: 7E0 907 047 AJ
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ROD: EV_ClimaticT5.rod
   VCID: 72ED9F76A5D771D2CF-8026
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 274162821
   Coding: 62A0303A0A212032002009742C2B8CD40F90708F60464D60320400220800
   Shop #: WSC 02737 022 1488586
   VCID: 2A5D471645877912B7-807E
   Subsystem 1 - Part No SW: 7E0 959 801 M    HW: 7E0 959 801 M  Labels: 7E0-959-801.CLB
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU023091662674724
   Coding: 0400A0
   Subsystem 2 - Part No SW: 7E0 959 802 M    HW: 7E0 959 802 M  Labels: 7E0-959-802.CLB
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU023091662672918
   Coding: 1400A0
03301 - Response Closing Status of Drivers Door
                    Reset counter: 149
                    Date: 2016.11.17
                    Time: 18:06:09
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231623206344
   Coding: 10800D
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_VN75.rod
   VCID: 71EF907AA0D14ACA36-8024
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag020 H08 0018
   Revision: --------    Serial number: 003V30029ZDA
   Coding: 000000000000000000000000000000003230
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3A7D7756BD27C992C7-806E
   Part No SW: 7E0 920 870 S    HW: 7E0 920 870 S
   Component: KOMBI         H03 1104
   Coding: 150B010300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
   VCID: 397F685AB821C28ACE-806C
   Revision: 23002001
   ROD: N/A
Readiness: N/A
The ABS module should have a Basic Setting called:
IDE05334-ENG114972 Reset tire pressure monitoring display warnings
PS: With a 2017 Vehicle, you really should keep your VCDS current and I would also urge you to Get Verified here.
skizauchensee.com
New Member
Austria
HC706237 (NRRT)
Sorry, I have tried this with the latest software and the results are the same.
I have also verified my cable serial number so I am not sure what the problem is.
When I go to the basic settings and "Reset tire pressure monitoring display warnings" it asks for a code and then all I get is an "Error" warning
Kind regards
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Using the basic setting is NOT the proper method to relearn the pressure. There are two different locations for the TPMS button. Depending on the vehicle options it's either in the center console/dashboard or it's located in the glovebox. Have you checked the glovebox?
skizauchensee.com
New Member
Austria
HC706237 (NRRT)
Unfortunately, there is no reset button for this on the dash, radio, steering wheel or glove box.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The simplest of all solutions, read the fine manual. ;) The owners manual (checked with your specific VIN via vw-bordbuch.de) clearly instructs to either use the multi-function-display menu or the glovebox button. The latter is only installed if the vehicle is NOT equipped with multi-function-display, according to your VIN you have PR-9Q5 (MFA+).
The menu in the cluster is described here...
Reset des Reifenfülldruckwarnblinkers
...a picture of the glovebox button can be found here.
reifendruckwarnung zurückstellen
If neither of these options seem to get you anywhere, I suggest you take the car to your dealer and have them figure out and explain to you how to reset your TPMS.
Danners74
C?ID=273244
   Revision: 23002001
   ROD: N/A
Readiness: N/A
0397 - TPMS Warning
                    Reset counter: 47
                    Mileage: 1453 km
                    Date: 2016.09.20
                    Time: 15:08:53
   Coding: 01
   Revision: 00001002
   Coding: 0000000003
   Coding: 0400A0
   Coding: 1400A0
                    Reset counter: 149
                    Date: 2016.11.17
                    Time: 18:06:09
   Coding: 10800D
   Coding: 150B010300
   Revision: 23002001
   ROD: N/A
Readiness: N/A
Should all be done via the steering wheel buttons and search through the menu on your dash insert. Hope this helps
Regards Danners
skizauchensee.com
New Member
Austria
HC706237 (NRRT)
Thanks Guys,
We have the multi-function display but as mentioned there is no reset button for this on the instrument panel, media radio (traffic button instead of car button), steering wheel or glove box.
i was hoping I would be able to do this with the VCDS.
Regards
Nigel
skizauchensee.com
New Member
Austria
HC706237 (NRRT)
On a final note when I go into basic settings to reset the TPMS I get the Error message "Error - security code required"
PetrolDave
Westbury, UK
C?ID=1423
What they are saying is that by searching through the menus (maybe RTFM?) you should find a TPMS reset option on the multi-function display - so there is no need for a physical switch.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
...just click the first link, in post #8. It includes instructions and pictures of the menu in question.
That link doesn't work for me.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Well, link fixed and I just made 2 photo's on my own T6.
