2016 GTI Autobahn PP DAP
spblat
C?ID=271740
I made one adaptation before completing this scan, and it is this:
Carbon Fiber MFD
17 - Instruments
Adaptation - 10
Select “display depiction”
Change to “Version 2” (default is Version 1)
Monday,29,February,2016,20:48:59:53379
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: [deleted]   License Plate: SPBLAT
Mileage: 7522km-4673mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 32 3C 42 44 52 55 5F
          75 A5 A9
VIN: [deleted]   Mileage: 7522km-4673miles
Address 01: Engine (J623-CXCB)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 091D00324464002F1000
   Shop #: WSC 00066 790 00060
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001002
   ROD: EV_ECM20TFS0205G0906259D_VW37.rod
   VCID: AF2E5FF2F6CD4F4657-80FA
Readiness: 1010 0101
   Part No SW: 0D9 300 020 J    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H53 4902
   Revision: 06253104    Serial number: TFK01505290519
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 9C74983E977BC4DE02-80C8
   Revision: 00000000    Serial number: 61435000000369
   Coding: 01FA6BA154200974007A020241C36880D62A9000408216B616435053C089
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
   VCID: FAB8BEA67D0F5AEEB0-80AE
16401 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 247
                    Mileage: 2222 km
                    Date: 2015.11.30
                    Time: 12:21:20
   Revision: 00021000    Serial number: 0370706267
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: BA387EA63D8F9AEEF0-80EE
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 00020014200100000105000012111402
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: C2C80646555FD22EA8-8096
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86582705151847
   Coding: 00111A464041A2E969E44000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00224
   ROD: EV_BCMBOSCH_AU37.rod
   Slave 1:
   Component: WWS    150515  043 0581
   Serial number:         150711202536
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S5Y15M06D02H17M37S05
   Coding: 90A8DD
   Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
   Component: J245 PS60.036  H06 0150
   Serial number: 03694817012302150844
   Coding: 181803
563221 - Databus
206085 - Remote Control
          B1311 54 [008] - Missing Calibration / Basic Setting
                    Fault Frequency: 56
                    Reset counter: 139
                    Mileage: 358 km
                    Date: 2015.10.17
                    Time: 16:30:02
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0054
   Revision: --------    Serial number: 39491514905317
   Coding: 0031165011
   ASAM Dataset: EV_EPHVA2CAU3700000 003021
   ROD: EV_EPHVA2CAU3700000_VW37.rod
   VCID: C7DE17527E7DF7067F-8092
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0400
   Serial number: 23041503272350
   Coding: 01045600FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   ROD: EV_ACCMRRBoschVW372_AU37.rod
1542 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
                    Reset counter: 139
                    Mileage: 7205 km
                    Date: 2016.02.28
                    Time: 14:01:00
   Serial number: 003GCR024YR$
   Seat occupant detection; front passenger side:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J15000356XM0B
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 001 206 15
   Serial number: 3570000000087A61641F
   Subsystem 3 - Part No SW: -----------    HW: 480 000 206 15
   Serial number: 358000000002A2547418
   Subsystem 4 - Part No SW: -----------    HW: 480 402 005 15
   Serial number: 3510002A51B0CB32215V
   Subsystem 5 - Part No SW: -----------    HW: 480 401 805 15
   Serial number: 3520002A31A2DCD54087
   Subsystem 6 - Part No SW: -----------    HW: 480 400 206 15
   Serial number: 3550002B11B41484B1F1
   Subsystem 7 - Part No SW: -----------    HW: 480 400 206 15
   Serial number: 3560002AF1B4148482EC
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150602400171
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   VCID: F3A693825A652BA6F3-80A6
   Part No SW: 5G1 920 856 A    HW: 5G1 920 856 A
   Component: KOMBI         342 6420
   Coding: 0BAD091AED98CF0502886A0B5000000000000000
   VCID: AC1448FEC7DB345E72-80F8
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 17061510002329
   Coding: 0101000830085900FB00023B1C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07027
   ROD: EV_GatewConti.rod
   VCID: F5A2AD9A54113596DD-80A0
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150000495270015124
   Coding: 35FFFF
   Revision: 00000000    Serial number: 15000144912004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: B424509E1FEB6C9E2A-80E0
Address 32: Differential Locks (J492)       Labels: 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00031.03.15
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
Address 3C: Lane Change (J1086)       Labels: None
   Component: HRE_Master    H11 0071
   Serial number: 0369530774
   Coding: 02011103
   ROD: EV_HREntryHella_SK37.rod
   VCID: BC3478BE37BBA4DEE2-80E8
   Lane Change Assistant 2:
   Serial number: 240615060505EE
   Coding: 003E13200000040000000000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: C3C603424A45DB26A3-8096
   Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D
   Serial number: 00000000000001577080
   Coding: 011000
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 9302
   ROD: EV_SteerAssisMQB.rod
   VCID: B73E67920E9D87860F-80E2
   Serial number: 180615060505OT
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D
   Serial number: 00000000000001495696
   Coding: 091000
   Coding: 021A01010B000400
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: C0CC0C4E5B53C03EBE-8094
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 876     HW: 3Q0 035 876
   Component: MU-S-NS-US    H25 0241
   Serial number: VWZAZ2R0232806
   Coding: 027300020000000051220002001808001F0203F401200105C6
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: F1AA998A207919B601-80A4
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H52 1028
   Serial number: VWZ8Z9RFC001PD
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 3G0 919 866 B    HW: -----------
   Component: NAR 2015/16  --- 0220
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0564
   Shop #: WSC 00066 790 00322
   ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 00000345370
   Coding: 0100000000020306000400010100000100
   ROD: EV_MFKBoschAU370_AU37.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 150523201780
   VCID: EB968BE20255F3663B-80BE
End-------------------------(Elapsed Time: 02:50)--------------------------
