Hi, I wonder if anyone can help. I live on a Scottish island and the few mechanics here are not interested in looking at my car. They said its too complicated! I have a 2015 Seat Alhambra 2.0 tdi. It wouldn't start one day, just cranked. No fuel was coming to the fuel filter so I replaced the in tank pump and the problem was gone.
Now 3 months later the car would start and cut out after about 5 seconds. Again showing P0087. I've replaced the fuel metering valve, pressure sensor and regulator and Ive had my injectors checked. Problem persists.
Except now I have P1065.
After extensive research I'm thinking I need to reset learnt values of the regulator and sensor. Can anyone help? I'm pulling my hair out.
P1065 is gone from this latest scan.
Sunday,24,March,2024,16:49:17:47619
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: VSSZZZ7NZFV520499 License Plate: KW15VWE
Mileage: 152540km-94783mi Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 20 25 2E 42 44 46 4C 52 53 56
61 62 72 77
VIN: VSSZZZ7NZFV520499 Mileage: 152540km-94783miles
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 HL HW: 03L 906 018 M
Component: R4 2,0L EDC H28 9959
Revision: 44H28--- Serial number: 00000000000000 CVN: 3F1692DE38D3FF82
Coding: 0019001A042501080000
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01103L906018HL 003008
ROD: EV_ECM20TDI01103L906018H_VW36.rod
VCID: 7BA3F809A36EC0E27A1-802E
VINID: 9A38EAAAA1DEA9698508010924D099EA4A
5227 - Fuel Rail/System Pressure
P0087 00 [10100111] - Too Low
Mileage: 152543 km
Date: 2024.03.24
Time: 22:36:03
Engine RPM: 1864.50 /min
Normed load value: 41.2 %
Coolant temperature: 16 °C
Intake air temperature: -30 °C
Voltage terminal 30: 12.620 V
Unlearning counter according OBD: 80
Fuel temperature: 10.3 °C
Mean injection quantity: 14.22 mg/stroke
Rail pressure regulation: status-Bits 0-7: 4
Fuel high-pressure: actual value: 217100 hPa
High fuel pressure: specified value: 600800 hPa
Pressure control valve adaptation factor: 1.0000
Fuel level: 35.00 l
5231 - Fuel Rail/System Pressure
Mileage: 152543 km
Date: 2024.03.24
Time: 22:36:04
Engine RPM: 1117.50 /min
Normed load value: 100.0 %
Voltage terminal 30: 12.900 V
Mean injection quantity: 24.77 mg/stroke
Fuel high-pressure: actual value: 114600 hPa
High fuel pressure: specified value: 594200 hPa
Fuel level: 35.00 l
Address 03: ABS Brakes Labels: 7N0-614-109.clb
Part No SW: 7N0 614 109 S HW: 7N0 614 109 S
Component: J104 C3 450M VD5A 0040
Revision: --H07--- Serial number: 00000008763778
Coding: 0020091
Shop #: WSC 00020 790 00000
VCID: 3D273611F17A0ED2045-8068
Fault Frequency: 40
Reset counter: 90
Mileage: 152543 km
Date: 2018.08.15
Time: 00:03:11
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 13.00 V
Bin. Bits: 00011110
Count: 191
Hex Value: 0x0000
Fault Frequency: 40
Reset counter: 90
Mileage: 152543 km
Date: 2018.08.15
Time: 00:03:11
Part No SW: 7N0 907 044 AG HW: 7N0 907 044 AG
Component: Clima-Sharan H02 0606
Revision: 00001K02
Coding: 021000C549
VCID: 75B7EE31854A96920C5-8020
Slave 1:
Subsystem 1 - Part No SW: 7N0 907 049 C HW: 7N0 907 049 C
Component: KBT-H 004 0103
Serial number: 20150310000000212860
9478929 - Diagnostic Line for Rear Air Blower
B10A3 11 [00001000] - Short to Ground
Reset counter: 130
Mileage: 152543 km
Date: 2024.02.27
Time: 14:21:28
Part No SW: 5K0 937 086 Q HW: 5K0 937 086 Q
Component: BCM PQ35 M 122 0174
Revision: BC122001
Coding: 40180A3F8925F1C0408800C81400816443519288426D29626480C72000C1
VCID: 42DD45ED8484712A797-8016
Subsystem 1 - Part No SW: 7N2 955 119 A HW: 7N2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 150227 033 0044
Serial number: 150305105007
Coding: 004DBD
Component: RLHS 037 0059
Serial number: S5Y15M03D28H05M38S43
Coding: 0228DD
Component: Sensor, DWA 0 005 0502
Reset counter: 90
Mileage: 152543 km
Date: 2018.08.15
Time: 17:43:40
Voltage: 11.65 V
Fault Status: 00101010
Reset counter: 130
Mileage: 152543 km
Date: 2018.07.19
Time: 13:39:48
Voltage: 11.80 V
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 7N0 919 475 A HW: 7N0 919 475
Component: PARKHILFE 8K H06 0012
Revision: -------- Serial number: 28291507002261
Coding: 108002
ASAM Dataset: EV_EPHVA18VW4280000 001005
ROD: EV_EPHVA18VW4280000.rod
VCID: 392F2201E9D232F228D-806C
Part No SW: 7N0 959 655 C HW: 7N0 959 655 C
Component: VW10Airbag00F H13 0014
Serial number: 003LGP5QNQU3
Coding: 003046
ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 3FDB4C19F7F61CC2169-806A
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60F6B8251B9D5
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS603F47281BDD-
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS603F17051BDDT
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS60C5DA261BDD4
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS60887D041B9DP
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 521 B HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0162
Revision: FF010018 Serial number: 20150328100913
Coding: 1082240000
Shop #: WSC 00046 412 00000
ROD: EV_SMLSNGVOLWS.rod
VCID: 3B233809E3EE00E23A1-806E
Subsystem 1 - Part No SW: 1P0 959 538 D HW: 1P0 959 538 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0103
Serial number: 00000000000000559881
Coding: E20000
Part No SW: 7N5 920 970 L HW: 7N5 920 970 L
Component: KOMBI H04 0905
Coding: 441F01
VCID: 41DF4AE181026A3260D-8014
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 G
Component: Zuheizer 051 3041
Revision: 00051000 Serial number: 09028242000000
Coding: 0000041
VCID: 38292705DE582BFAD73-806C
01407 - Flame Extinguished
Reset counter: 104
Mileage: 150063 km
Date: 2018.04.26
Time: 19:04:46
Start
Temperature: 34.0°C
Temperature: 34.0°C
Voltage: 14.81 V
02251 - Heater Unit Locked
Reset counter: 64
Mileage: 150298 km
Date: 2018.04.27
Time: 15:19:58
Part No SW: 7N0 907 530 AQ HW: 7N0 907 530 AL
Component: J533 Gateway H58 1653
Revision: H58 Serial number: 180315F1000752
Coding: 468203
VCID: 7F5B0C19B7F6DCC2569-802A
Fault Status: 00101110
Mileage: 152543 km
Date: 2018.08.10
Time: 13:43:46
Part No SW: 7N0 857 511 P HW: 8P0 857 511 C
Component: FLA H04 0012
Revision: AA001002
Coding: 0102816B74745D545420363E01
VCID: 40D94FE58A88633A6F3-8014
Component: IMMO H04 0905
VCID: 6A8DCD4DDCF4496A917-803E
Address 2E: Media Player 3
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 G HW: 7N0 959 793 G
Component: TSG FA H03 0553
Revision: Serial number: 0000140528452
Coding: 011106209001411011
VCID: 46D559FDA8AC4D0A55F-8012
Part No: 7N0 909 144 R
Component: EPS_ZFLS Kl. 275 3501
Revision: 00H21000
VCID: 42DD45ED8884712A797-8016
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 14.0 V
PD
Temperature: 8.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 G HW: 7N0 959 792 G
Component: TSG BF H03 0553
Revision: Serial number: 0000139636716
Coding: 011104209E01411011
VCID: 45D75EF195AA46125C5-8010
Part No SW: 3AA 907 801 J HW: 3AA 907 801 J
Component: J540 EPB4 VW-63206 0012
Revision: H19 Serial number: 00000000586338
Coding: 0024167
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: RCD310 EU T H06 5007
Revision: -----10S Serial number: VWZ4Z2R1198313
Coding: 01000400040024
VCID: 33331029CB3EC8A2E21-8066
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1653
Coding: 030F7859
VCID: 71BFDA21F1A2BAB2D0D-8024
Component: J367-BDM H07 0180
Serial number: 42070642521491611933
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
Part No SW: 7N0 959 794 G HW: 7N0 959 794 G
Component: TSG HL H04 0553
Revision: Serial number: 0000140823769
Coding: 010004200001411001
VCID: 47CB54F9AFA65402AE9-8012
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
Component: TSG HR H04 0553
Revision: Serial number: 0000140811290
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007670196245 Dataset Number: 5N0035729E 0001
Coding: 0A00000080010101
ROD: EV_UHVUMI.rod
VCID: 323D152D34A4C1AAE97-8066
End----(Elapsed Time: 01:41, VBatt start/end: 11.4V/11.5V. VIgn 11.5V)-----
