- Apr 25, 2023
- 29
- 3
- Northwich, UK
- C?ID=546157
Hi,
I retrofitted air con early this year but now its getting colder I've noticed no real heat coming from the air vents.
I've tested with VCDS and it seems like the climate control module isn't sending the correct specified output to turn the heat on full.
I've done a recirculation flap alignment and basic settings a few times and when it's doing the test its fully working and I get heat. I can also see the temp flap actuator moving to its highest and lowest settings so it seems like the wiring/component is fine.
I'm pretty sure the issue started after I installed the aircon.
If I view the live data the specified value only goes to 145 (the max hot setting is 225) so its as if the CCM isnt sending the correct info.
The only thing I can think of is coding but there doesnt seem to be any codes or adaptations that can be applied?
My CCM is:
Address 08: Auto HVAC
Control Module Part Number: 1K0 820 047 FT
Component and/or Version: Climatic PQ35 141 0909
Software Coding:
Work Shop Code: WSC 00000
VCID: 7BA3E4538FEFC5925A9-802E
Advanced Identification
Identification: BHB-001
Revision: 00141027
Date: 18.05.07
Test stand number: 0110
Manufacturer number: 0074
Flash Status
Programming Attempts: 0
Successful Attempts: 0
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 00000 000 00000
Flash Date: --.--.--
Misc.
Hardware number: 1K0 820 047 FT
VCDS Info:
Labels: 1K0-820-047.lbl
My CCM is:
Software Coding:
Revision: 00141027
Date: 18.05.07
Flash Status
Misc.
VCDS Info:
