- Apr 16, 2014
- 9
- -1
- C?ID=182407
hello
I have retro fitted factory front parking sensors to this vehicle with a hazard/parking sensor switch/drive select/traction switch from another A1 and parking module from another VAG group vehicle(same part number as an A1 with front sensors)
i have fault codes in the parking module probaly due to wrong coding,does anyone know the correct coding for this modification,the long coding helper is not available.
The fault in the 44 is part of another thread,i just wanted to get this sorted before i go to the workshop with ODIS for the dataset in 44.
thanks
thanks
riday,06,October,2023,15:48:02:48459
VCDS Version: 23.3.1.0 (x64) HEX-NET2 CB: 0.4631.5
VIN: WAUZZZGB6LR007735 License Plate:
Chassis Type: GB-AU27 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 42 44 4B 52 5F 75 A5 BB BC D6 D7
VIN: WAUZZZGB6LR007735 Mileage: 20234km-12572miles
Address 01: Engine (J623-DKRF) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 025 AL HW: 04C 907 309 BP
Component: R3 1.0l TFS H20 7054
Revision: DGH20000 CVN: 3D899775
Coding: 0219003223241D080000
Shop #: WSC 64298 005 1048576
ASAM Dataset: EV_ECM10TFS01104C906025AL 003001
ROD: EV_ECM10TFS011_AU27.rod
VCID: 6A86A9F1CCF43DEAB1F-803E
VINID: 9D196AAAA5D219C8800071C31403E878D4
Readiness: 0010 0000
Part No SW: 2Q0 614 517 AG HW: 2Q0 614 517 N
Component: ESC_base_vFGS H23 0242
Serial number: 08505473190805
Coding: 41094D4F354182B4B203AC1927DF43A649124D26224A24584454185545E4C2659248B2644452241A222A18AAA255D243BDAA4BC2BD
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004036
ROD: EV_Brake1BOSCHESPMQBA0_004.rod
VCID: 73B8B4959B3EFC22029-8026
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 83A 820 047 B HW: 83A 820 047 B
Component: AC Manuell el H04 0040
Revision: 20026000 Serial number: 00000000672729
Coding: 231000030000000010000000000000040000000000000000
Shop #: WSC 00049 770 00119
ASAM Dataset: EV_AirCondiFrontManAU326 001005
ROD: EV_AirCondiFrontManAU326.rod
VCID: 231884D56B5E2CA2329-8076
Part No SW: 5Q0 937 084 DL HW: 5Q0 937 084 DK
Component: BCM MQBAB MxL H40 0312
Serial number: 00101921501146 Dataset Number: 82A909514C 0040
Shop #: WSC 00049 770 00084
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020_VW26.rod
VCID: 055CFA4DC5AAF2923CD-8050
Subsystem 1 - Part No SW: 81A 955 559 A HW: 81A 955 559 Labels: 5Q0-955-547.CLB
Component: G397_RLS H06 0002
Serial number: 20386945X81A955559A0
Coding: 80004D
Subsystem 2 - Part No SW: 4K2 941 501 R HW: 4K2 941 501 R
Component: E1 - LTM H06 0060
Serial number: 17S24.01.2000300398
Subsystem 3 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY193400ZDA
Serial number: 00000000000048006151
Steering Column Switch:
Subsystem 5 - Part No SW: 82A 953 521 DS HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0070
Serial number: 00000007081920240214
Part No SW: 5QA 919 294 J HW: 5QA 919 294
Component: PDC 8 Kanal H08 0073
Serial number: 000150058320219 Dataset Number: V03935314JL 0001
Coding: 8471455841
Shop #: WSC 00033 790 00207
ASAM Dataset: EV_EPHVA18AU3700000 009053
ROD: EV_EPHVA18AU3700000_AU27.rod
VCID: 53F814157B7E9C22E29-8006
12658704 - Databus
[Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
Reset counter: 182
Mileage: 20210 km
Date: 2023.10.02
Time: 00:39:38
13639168 - Databus
[Steuergerät für Rear Cross Traffic Alert - RCTA_01 - kein Signal / keine Kommunikation]
Reset counter: 184
Mileage: 20210 km
Date: 2023.10.02
Time: 00:39:38
Part No SW: 2Q0 907 572 R HW: 5Q3 907 572
Component: ACCCONTIMQB H03 0372
Dataset Number: 82A909863E 0004
Coding: 2A00008108FF8728747C61450050A700080000000000000004
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 43D824558B1E0CA2529-8016
Part No SW: 2Q0 959 655 AM HW: 2Q0 959 655 AM
Component: VW22Airbag 012 0351
Revision: -------- Dataset Number: 82A909602E 0007
Coding: 88CCC0C0000000005C5400DF008840A80065
Shop #: WSC 00049 770 00131
ASAM Dataset: EV_AirbaVW22BPAVW27X 001020
ROD: EV_AirbaVW22BPAVW27X_VW27.rod
VCID: 0842F379F2B8EFFA47B-805C
Subsystem 1 - Part No SW: ----------- HW: 442 060 507 19
Serial number: 3577Y509930D5EC313DH
Subsystem 2 - Part No SW: ----------- HW: 442 060 507 19
Serial number: 3587Y509B30D5EC1A3CQ
Subsystem 3 - Part No SW: ----------- HW: 442 0B1 406 19
Serial number: 3517713A73277E035302
Subsystem 4 - Part No SW: ----------- HW: 442 0B1 406 19
Serial number: 3527713A53277E01E0FK
Subsystem 5 - Part No SW: ----------- HW: 442 132 601 20
Component: FrontSensor_D 290 118A
Serial number: 355AG11A131E72E3E5A$
Part No SW: 82A 920 710 A HW: 82A 920 710 A
Component: KOMBI H01 4190
Coding: 24A40000698026000180A0401000000000000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001041
ROD: EV_DashBoardVDDMQBA0_AU27.rod
VCID: 1F10882547360842161-804A
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 20081910804107 Dataset Number: 82A909515C 0014
Coding: 030100F42F0857005B000248080B00000000000000000000000000000000
GVL: 01463C0000000000408C80008000480000000000000200000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 70B2BB99EA28C73AFFB-8024
Generator:
Component: 5-01-14-01-04
Subsystem 2 - Part No SW: 82A 951 523 A HW: 82A 951 523 A
Component: E221__MFL H07 0003
Serial number: 10S07000338018919179
Subsystem 3 - Part No SW: 2Q0 915 181 B HW: 2Q0 915 181 B
Component: J367-BDMBOSCH H02 2012
Serial number: 1007064E
Part No SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0485
Serial number: 0000386398201 Dataset Number: 82A909872C 0011
Coding: 00100220F001020000001000
ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
VCID: 4DCC026D5D5ACAD2B4D-8018
Subsystem 1 - Part No SW: 5Q0 959 408 HW: 5Q0 959 164
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000033208463
Coding: 2D0000
Address 44: Steering Assist (J792) Labels:* 2Qx-909-144-V1.clb
Part No SW: 2Q2 909 144 M HW: 2Q2 909 144 F
Component: TRW_G4L_MQBA0 621 6041
Serial number: 1396263CB4K2412
Coding: 010000000100000101010201010001010000010101
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
ROD: EV_SteerAssisTRWG4LMQBA0.rod
VCID: 3D2C52ADEDFA7A5224D-8068
10529280 - Data Set Missing
U1118 00 [009] - -
[DEM_NO_INITIAL_VW_DSDL_FAULT]
Reset counter: 184
Mileage: 20228 km
Date: 2023.10.03
Time: 09:30:31
Engine RPM: 961 /min
System status: Driving mode
Terminal 15 status: On
Voltage terminal 30: 14.78 V
Power steering current consumption: 0.5 A
max.value: 12.6 A
End stage temperature: 22 °C
Steering assistance: engine output: 100 %
Engine angle: 75 °
Electric motor speed: 0 /min
Steering assistance: target engine torque: 0.0 Nm
Steering torque: 0.0 Nm
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 20081911603626 Dataset Number: 82A909583A 0009
Coding: 000000070900204600002900020000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003.rod
VCID: 37204085CFC65002FE1-8062
Part No SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0485
Serial number: 0000386942003 Dataset Number: 82A909873C 0013
Coding: 00100020FC01020000001000
ROD: EV_DCU2PasseSideMAXHCONT_VW41.rod
VCID: 4CCA0F69A640C3DAA33-8018
Subsystem 1 - Part No SW: 5Q0 959 407 HW: 5Q0 959 163
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000033091832
Coding: 350000
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-STD2.clb
Part No SW: 83A 035 842 A HW: 83A 035 842
Component: MU-S-D-ER 743 2628
Serial number: Dataset Number: 82A909545F 0011
Coding: 01720000BE00000043111101C00800002F0007E60170000002
ASAM Dataset: EV_MUStdGen2pDELP 001001
ROD: EV_MUStdGen2pDELP.rod
Multimedia System 1:
Subsystem 1 - Part No SW: 82A 919 604 B HW: 82A 919 604 B
Component: DU AU270 Std H44 0137
Serial number: MA18X0AEB0355639
Volume Control 1:
Subsystem 2 - Part No SW: 82A 919 616 A HW: 82A 919 616
Component: LSR-D5/C8 H33 0110
Serial number: 00004420000002211047
Part No SW: 5WA 035 282 HW: 5WA 035 282
Component: OCUGen3Low H14 0083
Serial number: 0000000907NVTD3
Coding: 013260101FE820848005460120090000
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low_AU27.rod
VCID: 0154EE5DD182DEB2005-8054
Part No SW: 3Q0 980 654 M HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0451
Serial number: 23051915P14509 Dataset Number: 82A909466C 0006
Coding: 0402070000000401000200448156440084000E20000000
ROD: EV_MFKBoschMQBB_002.rod
VCID: 41D42E5D91021EB2405-8014
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Part No SW: 4K0 941 572 CC HW: 4K0 941 572 C
Component: LMS_MQB H06 0031
Dataset Number: 82A909471B 0005
ROD: EV_LMSLeftHELLAAU58X.rod
VCID: 71B4BE9DE122CE32F05-8024
Dataset Number: 82A909472B 0005
End----------(Elapsed Time: 01:16, VBatt start/end: 14.5V/14.5V)-----------
