Virtual cluster coding needed, MK7 GTI
9900rpm
C?ID=83902
I installed the virtual cluster from a Tiguan into my GTI. Everything works, minus the navigation (did not connect optical cable yet). My question is, can I change the car icon in the middle from the Tiguan to a GTI? Also, the speedometer seems to read about 10mph higher than it should. Anyone know which variant or setting is correct for GTI? I did get the fuel level part worked out. Have seen others with a wrong fuel gauge. Mine does read correctly.
The only adaptations I have played with and used i the color change, from the blue background to golden orange.
Copy of my full scan below. Not sure if it's needed or not.
Monday,19,February,2018,15:30:42:59930
VCDS Version: 18.2.0.3 (x64)
VIN: 3VW447AU2GM062648   License Plate: KFE6129
Mileage: 27570mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 2B 32 3C 42 44 47 52 55 5F
          75 A9
VIN: 3VW447AU2GM062648   Mileage: 44369km-27569miles
Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00124424002F1000
   Shop #: WSC 11290 003 1048576
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
   ROD: EV_ECM20TFS0205G0906259D.rod
   VCID: 2F6DE07D76F7563CB1-807A
Readiness: 1110 1101
   Part No SW: 0D9 300 020 J    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H53 4931
   Revision: 06253104    Serial number: TFK01602271683
   Coding: 0018
   Shop #: WSC 01357 011 12345
   ROD: EV_TCMDQ250021.rod
   VCID: 1C3727B11741DDA4E4-8048
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-ESP-V1.clb
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 50986000001224
   Coding: 01FA6BA15426096E007D020441CB6880D62A9000408216B6004300D1C088
   VCID: 4B9594EDE22F0A1CBD-801E
8295 - Tire Diameter Implausible
          C10A8 00 [009] -  -
                    Reset counter: 91
                    Mileage: 44369 km
                    Date: 2018.02.19
                    Time: 15:24:15
   Revision: 00021000    Serial number: 0395800643
   Coding: 030C0C
   Shop #: WSC 01383 790 50316
   VCID: 3A7BC129BDB5839416-806E
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 00020014100100000005004012111402
   VCID: 428BB9C9D565CB544E-8016
   Air quality sensor:
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 865818031601HP
   Coding: 00111A464041A2F969E44000001407201800000000000000000000000000
   Shop #: WSC 62322 002 104857
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7AFB0129FD35439456-802E
   Component: WWS    150907  043 0581
   Serial number:         160331010754
   Component: RLHS  037 0059
   Serial number: S2Y16M02D26H04M26S56
   Coding: 90A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
   Component: J245 PS60.036  H06 0150
   Serial number: 03691620011001162045
   Coding: 181803
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 02031641350016
   ROD: EV_DRCONTITEMIC_VW27.rod
   VCID: 377DD81D8EA79EFCE9-8062
   Serial number: 003GCR04J89C
   Shop #: WSC 00066 790 00211
   VCID: 479DA8DDFE47EE7C99-8012
   Occupant Detection:
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH000000000004XAIN5
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 002 502 16
   Serial number: 35700000000B4224691B
   Subsystem 3 - Part No SW: -----------    HW: 480 002 502 16
   Serial number: 358000000006FA71591R
   Subsystem 4 - Part No SW: -----------    HW: 480 400 603 16
   Serial number: 35100029F1F93A03B2AD
   Subsystem 5 - Part No SW: -----------    HW: 480 400 603 16
   Serial number: 3520002B71F93A01330W
   Subsystem 6 - Part No SW: -----------    HW: 480 402 002 16
   Serial number: 3550002BB1F93A3612EF
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 002 16
   Serial number: 3560002BB1F93A35B2EP
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160310500041
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 04077FD18FF105643C-8050
   Part No SW: 5NA 920 891 B    HW: 5NA 920 891 B
   Component: KOMBI         407 3193
   Coding: 0BAD091B3988CF0502086A085000000000000000
   VCID: 4385BCCDCA7FC25C45-8016
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 24021610800036
   Coding: 0101000830085900FB00022B9C0F00000001050000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 79F91E25F833488C5F-802C
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160003491200067021
   Coding: 31FFFF
   Revision: 00000000    Serial number: 16000044893005
   Coding: 5D00000000000000
   Shop #: WSC 00066 790 00322
   ROD: EV_ELVMarquMQB.rod
   VCID: 3467EF119FD175E4CC-8060
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00013.01.16
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Component: HRE_Master    H11 0071
   Serial number: 0390858946
   Coding: 02022103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C77C731B781BDA404-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H11 0071
   Serial number: 0390811542
   Coding: 020221
337312 - Databus
                    Reset counter: 91
                    Mileage: 44369 km
                    Date: 2018.02.19
                    Time: 15:24:12
388357 - Databus
                    Reset counter: 91
                    Mileage: 44369 km
                    Date: 2018.02.19
                    Time: 15:24:12
   Serial number: 160416060500W3
   Coding: 003F13205000020000000000
   Serial number: 00000000000012273761
   Coding: 011000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8102
   Shop #: WSC 00066 790 00149
   VCID: 3979DE25B8B3888C1F-806C
20484 - Databus
                    Reset counter: 91
                    Mileage: 44369 km
                    Date: 2018.02.19
                    Time: 15:24:12
                    Motor status: 00
                    Supply voltage: 11.75 V
                    Temperature: 43.0 °C
                    KFC: 50
                    KFA: 00 04
                    Environmental conditions: 7F
                    uioUdNotFilt_xdu16: 11.94 V
                    uAdSensI_SwitchedKl30_xdu16: 11.94 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
   Component: MIB2_lite_amp H20 0150
   Revision: 00000001    Serial number: VWZ8Z1FBA01K8TL
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6DD13A75BC7BE42CC3-8038
   Serial number: 160416060502PC
   Coding: 003F13205C00020000000000
   Serial number: 00000000000012076053
   Coding: 091000
   Coding: 021203000B000400
   VCID: 408FB3C1DB69D94458-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 3Q0 035 876     HW: 3Q0 035 876
   Component: MU-S-NS-US    820 0613
   Coding: 027300020000000051220002001808001F0203F401200105C6
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 71E92605A04300CCE7-8024
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9SJX0045C
   Subsystem 2 - Part No SW: 3G0 919 866 R    HW: -----------
   Component: NAR 2016  --- 0321
6696 - Instrument Cluster Control Module on Optical Bus
          U10C0 00 [009] - No Communication
                    Reset counter: 91
                    Mileage: 44369 km
                    Date: 2018.02.19
                    Time: 15:24:15
                    Voltage terminal 30: 12.0 V
   Component: OCULowMQBUS   007 0568
   ROD: EV_OCULowMQB.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 160131200154
   VCID: 6BD5346D826FEA1CDD-803E
End-------------------------(Elapsed Time: 04:49)--------------------------
MasterTommy
Amsterdam
C?ID=295586
Please post an admap of 17 and 5F.
I believe the display model variant was under coding, but i’d have to double check. Ross-tech could probably tell you what the value should be if they have a MK7 with AID in their database, provided we can identify where the setting exactly is...
^^^ MasterTommy: Apropos of this matter, can you help with my understanding of AID clusters in newer mk7s - is the software switch for the optical fiber connection to the 5F module in Byte 22, Bit 0 =0 (as below)?
MasterTommy
Amsterdam
C?ID=295586
I'll have to check my Tiguan tomorrow. But i thought only the navigational map was streamed over MOST, and normal messages over CAN. That bit you're talking about isn't about the latter.
Anyway, even with my admaps and coding we'll still need to see at least an admap of 17...
9900rpm
C?ID=83902
I got my admaps. How do I attach them to this forum? The bottom of the page says I don't have permission. it's a .csv file.
hadez16
C?ID=289891
Here is a (german) Auto-Scan excerpt of a german MK7.5 GTI with AID:
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei: DRV\5G0-920-XXX-17.clb
   Teilenummer SW: 5G1 920 791     HW: 5G1 920 791
   Bauteil: KOMBI         409 2180
   Codierung: 07AD19083F84000801886B011401000000000000
   Betriebsnr.: WSC 01357 011 00200
   ASAM Datensatz: EV_DashBoardVDDMQBAB 009052
   VCID: 69DE768188E24F095E-803C
Kein(e) Fehlercode(s) gefunden.
I do not have an adpmap of 17. Shame on me.
kamold
Australia
C?ID=241363
Here is an admap from a Golf R MY15 retrofitted with 7.5 AID. It has Golf image in the cluster.
Can't see which setting controls the image from a quick glance over the available options. It could be a parameter set perhaps?
Cluster was installed using ODIS online
;SW:5G1-920-791   HW:5G1-920-791 ---  Instruments
;Component:KOMBI         410 2180	 Coding:27AD0818BF80000801886A011400000000000000
;EV_DashBoardVDDMQBAB	9052	EV_DashBoardVDDMQBAB_009_VW37.rod
;Tuesday	20	February	2018	11:27:20:58930
;VCDS Version: Release 18.2.0 (x64)  Data version: 20180212 DS287.0
;VCID: 698F436F89F7816FC56-803C
IDE00295-Oil temperature display	On 	1
IDE00301-Distance	18824 km	3
IDE00342-ESI: Resetting ESI	no warning 	1
IDE00343-Language version	English 	1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK	Manual reset: not possible 	3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel	MFA3-Reset 	3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas	MFA3-Reset 	3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection	MFA3-Reset 	3
IDE00499-Display correction of consumptions and operating range	100%	1
IDE00500-Hour	11 H	1
IDE00501-Minute	26 min	1
IDE00502-Year	2018 yr	2
IDE00503-Month	2 mon	1
IDE00504-Day	20 d	1
IDE00510-ESI: distance driven from inspection	1776 km	3
IDE00511-ESI: time from inspection	122 d	2
IDE00512-ESI: minimum value km-driving distance/inspection	15000 km	2
IDE00513-ESI: maximum value km-driving distance/inspection	30000 km	2
IDE00514-ESI: maximum value of time between inspections	730 d	2
IDE00515-ESI: oil quality	poor oil quality 	1
IDE00517-ESI: soot entry	0 km	2
IDE00518-ESI: thermal load	4000 km	2
IDE00819-Day counter	1260 d	2
IDE00820-Activating and deactivating all development messages	not active 	1
IDE00827-ESI: minimum value of time between inspections	365 d	2
IDE01153-SIA: maximum value of distance to service	15000 km	2
IDE01154-SIA: maximum value of time to service	365 d	2
IDE02489-Display depiction	Version 1 	1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration	-12.8 l	5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1	-12.8 l	5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2	-12.8 l	5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3	12.7 l	5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4	12.7 l	5
IDE03329-Driving profiled for range remaining	5.5 l/100km	2
IDE03346-IDE00301-Units adjusted-Distance	Kilometers 	3
IDE03346-MAS01230-Units adjusted-Date	dd_mm_yy 	3
IDE03346-MAS01456-Units adjusted-Speed	Kilometers per hour 	3
IDE03346-MAS02201-Units adjusted-Temperature	Degrees Celsius 	3
IDE03346-MAS02957-Units adjusted-Time	12h AM_PM 	3
IDE03346-MAS03032-Units adjusted-Volume	Liter 	3
IDE03346-MAS03034-Units adjusted-Pressure	bar 	3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas)	kg per 100 km 	3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)	Liters per 100 km 	3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive	kWh per 100 km 	3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground	kilogram (kg) 	3
IDE03348-MAS01456-Speed warning-Speed	0	2
IDE03348-MAS01561-Speed warning-Unit	Kilometers per hour 	2
IDE03348-Speed warning-	not active 	2
IDE03349-FIX: Max. distance until next mileage-related inspection	15000 km	2
IDE03350-FIX: Maximum time until next time-dependent inspection	365 d	2
IDE03351-FIX: Distance covered since last mileage-dependent inspection	1700 km	2
IDE03352-FIX: Time since last time-dependent inspection	122 d	2
IDE03372-Source for synchronization of time	internal clock 	1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function	On 	5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time	10 s	5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic	On 	5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless	On 	5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed	20 km/h	5
IDE03568-ENG103545-Service-key settings-p_write_delay_time	40 s	5
IDE03568-ENG104099-Service-key settings-p_write_distance	20 km	5
IDE03867-Deactivate seat belt warning	No 	1
IDE05930-Service notification in days	30 d	1
IDE05931-FIX: Reset value for next mileage-dependent inspection	30000 km	2
IDE05932-FIX: Reset value for next time-dependent inspections	365 d	2
IDE05971-Vehicle Positioning System Interface Control Module	not installed 	1
IDE06425-Roller test bench mode: functional	not activated 	1
IDE06588-Ignition active message: actuator	Driver door 	1
IDE07221-Cylinder shut-off	Display 	1
IDE11086-Service notification	0 d	1
IDE11932-MAS01877-Display of colour adjustment-Red	0	3
IDE11932-MAS01878-Display of colour adjustment-Green	0	3
IDE11932-MAS01879-Display of colour adjustment-Blue	0	3
MAS03555-Lap counter	Display 	1
ENG117917-BAP_Debug_Mode_Release	not_released 	1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1	OFF 	20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10	OFF 	20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11	OFF 	20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12	OFF 	20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13	OFF 	20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14	OFF 	20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15	OFF 	20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16	OFF 	20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17	OFF 	20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18	OFF 	20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19	OFF 	20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2	OFF 	20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20	OFF 	20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21	OFF 	20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22	OFF 	20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23	OFF 	20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24	OFF 	20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25	OFF 	20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26	OFF 	20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27	OFF 	20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28	OFF 	20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29	OFF 	20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3	OFF 	20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30	OFF 	20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31	OFF 	20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32	OFF 	20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33	OFF 	20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34	OFF 	20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35	OFF 	20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36	OFF 	20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37	OFF 	20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38	OFF 	20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39	OFF 	20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4	OFF 	20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5	OFF 	20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6	OFF 	20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7	OFF 	20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8	OFF 	20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9	OFF 	20
ENG119875-defuel_threshold	9 l	1
ENG128744-ENG101574-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X1	00 00 	24
ENG128744-ENG99557-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X2	00 0A 	24
ENG128744-ENG102140-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X3	00 32 	24
ENG128744-ENG102936-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X4	00 64 	24
ENG128744-ENG103548-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X5	00 96 	24
ENG128744-ENG113992-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X6	00 FD 	24
ENG128744-ENG99777-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y1	00 32 	24
ENG128744-ENG100480-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y2	00 32 	24
ENG128744-ENG100773-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y3	00 78 	24
ENG128744-ENG100631-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y4	00 E6 	24
ENG128744-ENG102174-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y5	01 F4 	24
ENG128744-ENG113993-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y6	03 E8 	24
ENG128743-ENG101574-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X1	00 00 	24
ENG128743-ENG99557-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X2	00 0A 	24
ENG128743-ENG102140-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X3	00 64 	24
ENG128743-ENG102936-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X4	00 96 	24
ENG128743-ENG103548-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X5	00 DC 	24
ENG128743-ENG113992-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X6	00 FD 	24
ENG128743-ENG99777-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y1	00 09 	24
ENG128743-ENG100480-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y2	00 09 	24
ENG128743-ENG100773-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y3	00 50 	24
ENG128743-ENG100631-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y4	01 90 	24
ENG128743-ENG102174-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y5	03 52 	24
ENG128743-ENG113993-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y6	03 E8 	24
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1	00 00 	20
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2	00 01 	20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3	00 32 	20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4	01 2C 	20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5	01 F4 	20
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1	00 00 	20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2	00 0A 	20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3	00 32 	20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4	00 96 	20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5	00 FD 	20
ENG119874-Gas_functionality	not active 	1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim	terminal_58xd_log_bus_parkinglight 	1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm	parking_light 	1
ENG119882-init_fuel_algorithm	No 	1
ENG130585-Leaving_warning_delay	1.6 s	1
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0	15 s	16
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature	4 °C	16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature	6 °C	16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta	25 °C	16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0	5.0 km	16
ENG102605-ENG103631-outside_temperature-P_speed_threshold	20 km/h	16
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off	180 min	16
ENG102605-ENG104179-outside_temperature-p_tendency_damping	15 s	16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold	1.0 °C	16
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1	40 s	16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping	2	16
ENG119825-Picture_Upload_Download	not active 	1
ENG126396-Scale_switching_algorithm	lowbeam_foglight 	1
ENG119876-Service_Key_Clear_All_Counter	Yes 	1
ENG130584-Statistic_phev_mileage	5 km	1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms	2.0 s	18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms	5 s	18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt	35 s	18
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF	300 ms	18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms	255 s	18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms	5 s	18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms	6 s	18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms	20 s	18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms	900 s	18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms	10 s	18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms	3 s	18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms	10 s	18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ	0.20 s	18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse	3	18
ENG109442-ENG101663-time_parameter_display-tDD15_off	0.15	18
ENG109442-ENG103975-time_parameter_display-tDD15_on	0	18
ENG109442-ENG100026-time_parameter_display-tDDWUP	0	18
ENG112418-ENG112412-total_range_gas-consumption_factor	0	4
ENG112418-ENG112411-total_range_gas-consumption_profile	consumption_profile_calculation 	4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor	consumption_factor_CAN 	4
ENG112418-ENG99298-total_range_gas-State	not active 	4
ENG153766-Tube_version	variant_0 	1
Elapsed Time: 00:26
;Tuesday	20	February	2018	11:27:50:58930
MasterTommy
Amsterdam
C?ID=295586
Its in coding, made screens last night, will post them up later.
9900rpm
C?ID=83902
;SW:5NA-920-891-B   HW:5NA-920-891-B ---  Instruments
;Component:KOMBI         407 3193	 Coding:0BAD091B3988CF0502086A085000000000000000
;EV_DashBoardVDDMQBAB	9058	EV_DashBoardVDDMQBAB_009_VW37.rod
;Wednesday	21	February	2018	00:45:06:59930
;VCID: 4385BCCDCA7FC25C45-8016
IDE00301-Distance	44666 km	3
IDE00343-Language version	US English 	1
IDE00500-Hour	0 H	1
IDE00501-Minute	45 min	1
IDE00504-Day	21 d	1
IDE00510-ESI: distance driven from inspection	12831 km	3
IDE00511-ESI: time from inspection	192 d	2
IDE00518-ESI: thermal load	26200 km	2
IDE00819-Day counter	649 d	2
IDE01153-SIA: maximum value of distance to service	16100 km	2
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2	12.7 l	5
IDE03329-Driving profiled for range remaining	8.8 l/100km	2
IDE03346-IDE00301-Units adjusted-Distance	miles 	3
IDE03346-MAS01230-Units adjusted-Date	mm_dd_yy 	3
IDE03346-MAS01456-Units adjusted-Speed	Miles per hour 	3
IDE03346-MAS02201-Units adjusted-Temperature	Degrees Fahrenheit 	3
IDE03346-MAS03032-Units adjusted-Volume	gallons (US) 	3
IDE03346-MAS03034-Units adjusted-Pressure	psi 	3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)	Miles per gallon (US) 	3
IDE03348-MAS01561-Speed warning-Unit	Miles per hour 	2
IDE03349-FIX: Max. distance until next mileage-related inspection	32200 km	2
IDE03350-FIX: Maximum time until next time-dependent inspection	730 d	2
IDE03351-FIX: Distance covered since last mileage-dependent inspection	12700 km	2
IDE03352-FIX: Time since last time-dependent inspection	192 d	2
IDE03372-Source for synchronization of time	GPS 	1
IDE05931-FIX: Reset value for next mileage-dependent inspection	32200 km	2
IDE05932-FIX: Reset value for next time-dependent inspections	730 d	2
IDE11086-Service notification	30 d	1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation	not active 	1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS	not active 	1
ENG153765-Second_digital_speed	Display 	1
Elapsed Time: 00:34
9900rpm
C?ID=83902
5F
;SW:3Q0-035-876   HW:3Q0-035-876 ---  Information Electr.
;Component:MU-S-NS-US    820 0613	 Coding:027300020000000051220002001808001F0203F401200105C6
;EV_MUStd4CDELP	1001	EV_MUStd4CDELP_VW27.rod
;Wednesday	21	February	2018	00:47:00:59930
;VCID: 71E92605A04300CCE7-8024
IDE00001-Production mode	00 00 00 	3
IDE00346-Summertime-automatic	manual 	1
IDE00758-Base volume of telephone	50%	1
IDE00759-Base volume of speech output	50%	1
IDE00760-Microphone sensitivity	0 dB	1
IDE00769-Number 1 for Info call	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE00770-Number 1 for roadside assistance	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages	OFF 	1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages	OFF 	1
IDE00845-Wheel circ.	0 mm	2
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module	Yes 	3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner	No 	3
IDE01996-MAS00844-Installation list: specified installations-Radio	No 	3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module	Yes 	3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1	Yes 	3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2	No 	3
IDE01996-MAS04300-Installation list: specified installations-DVD changer	No 	3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module	No 	3
IDE01996-SFT271943-Installation list: specified installations-Multimedia Operating Unit	No 	3
IDE01996-ENG154341-Installation list: specified installations-Reserved_8	No 	3
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1	No 	3
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2	No 	3
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1	No 	3
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2	No 	3
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1	No 	3
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2	No 	3
IDE02121-CD eject button	Enabled 	1
IDE02122-Developer mode	not activated 	1
IDE02330-Number 2 for Info call	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE02331-Number 2 for roadside assistance	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE02332-Deactivate production mode	0	3
IDE02476-MAS03001-Electrical test of loudspeakers-Mode	automatic 	49
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency	19000 Hz	49
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume	27	49
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency	19000 Hz	49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume	27	49
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency	19000 Hz	49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume	27	49
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency	19000 Hz	49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume	27	49
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency	19000 Hz	49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume	27	49
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency	19000 Hz	49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume	27	49
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency	19000 Hz	49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume	27	49
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency	19000 Hz	49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume	27	49
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency	19000 Hz	49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume	27	49
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency	19000 Hz	49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume	27	49
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency	19000 Hz	49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume	27	49
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency	19000 Hz	49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume	27	49
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency	19000 Hz	49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume	27	49
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency	19000 Hz	49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume	27	49
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency	19000 Hz	49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume	27	49
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency	19000 Hz	49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume	27	49
IDE02502-Confirmation of installation change	5C E4 	2
IDE02607-Wheel pulse	0	2
IDE02699-Number 1 for roadside assistance	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE02701-Number 1 (roaming) for roadside assistance	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE03471-ENG117847-Vehicle configuration-advanced_range_display	OFF 	30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing	OFF 	30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO	On 	30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless	OFF 	30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life	OFF 	30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios	OFF 	30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless	OFF 	30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless	OFF 	30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb	blocked 	30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant	0	30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call	On 	30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support	OFF 	30
IDE03471-ENG185778-Vehicle configuration-FoD	SWaP 	30
IDE03471-ENG130248-Vehicle configuration-Google_GAL	On 	30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless	OFF 	30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts	OFF 	30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other	OFF 	30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts	OFF 	30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other	OFF 	30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data	not activated 	30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender	Deactivated 	30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1	Not Present 	30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2	Not Present 	30
IDE03471-ENG127492-Vehicle configuration-LGI	OFF 	30
IDE03471-ENG130246-Vehicle configuration-LTE_modul	activated 	30
IDE03471-ENG142142-Vehicle configuration-map_email_support	OFF 	30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support	OFF 	30
IDE03471-ENG142141-Vehicle configuration-map_sms_support	OFF 	30
IDE03471-ENG142152-Vehicle configuration-Map_Style	0	30
IDE03471-ENG152537-Vehicle configuration-media_control	not activated 	30
IDE03471-ENG138662-Vehicle configuration-Mirror_link	OFF 	30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code	MIB_EU 	30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference	RGB565 	30
IDE03471-ENG117843-Vehicle configuration-my_audi	OFF 	30
IDE03471-ENG117845-Vehicle configuration-online_dictation	OFF 	30
IDE03471-ENG127495-Vehicle configuration-online_media	OFF 	30
IDE03471-ENG117840-Vehicle configuration-online_navigation	OFF 	30
IDE03471-ENG117837-Vehicle configuration-online_POI	OFF 	30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice	OFF 	30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services	OFF 	30
IDE03471-ENG152553-Vehicle configuration-online_radio	Deactivated 	30
IDE03471-ENG117841-Vehicle configuration-online_street_view	OFF 	30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit	OFF 	30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold	0	30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis	0	30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy	0	30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode	Data & language service active 	30
IDE03471-ENG117844-Vehicle configuration-picture_navi	On 	30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking	not activated 	30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use	not activated 	30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest	0	30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi	OFF 	30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo	OFF 	30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version	PSD_1.5 	30
IDE03471-ENG117846-Vehicle configuration-remote_HMI	OFF 	30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component	activated 	30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open	not activated 	30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold	not activated 	30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe	not activated 	30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input	FBAS 	30
IDE03471-ENG152556-Vehicle configuration-scon_telephony	not activated 	30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation	no restriction 	30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag	no_region 	30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch	not activated 	30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch	Not Present 	30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support	OFF 	30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi	activated 	30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode	0	30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold	OFF 	30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling	On 	30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone	On 	30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location	OFF 	30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability	OFF 	30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving	blocked 	30
IDE03471-ENG137647-Vehicle configuration-UOTA	OFF 	30
IDE03471-ENG167532-Vehicle configuration-UOTA_2	OFF 	30
IDE03471-ENG117852-Vehicle configuration-UPnP	OFF 	30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound	not activated 	30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound	not activated 	30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte	not activated 	30
IDE03471-ENG117836-Vehicle configuration-VZAPro	OFF 	30
IDE03471-ENG127494-Vehicle configuration-VZO	OFF 	30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI	OFF 	30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot	OFF 	30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch	not activated 	30
IDE03902-Automatic ring break diagnostic	No automatic start 	1
IDE04295-Bluetooth: Preferred connection profile for phone book data	PBAP 	1
IDE04331-Selection of release codes for a SWaP function	FF FF FF FF 	4
IDE04521-Sporadic ring break detection	Visual 	1
IDE04522-Awakening ability on optical databus	OFF 	1
IDE04550-Bluetooth: Sniff mode	OFF 	1
IDE05111-Fee-based traffic information (TMC)	1537	2
IDE05113-Infotainment Recorder	activated 	1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass	OFF 	1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default	On 	1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS	OFF 	1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo	OFF 	1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass	OFF 	1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1	OFF 	1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2	OFF 	1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner	-128	40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio	5	40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM)	-128	40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM)	-128	40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB)	-128	40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB	-128	40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP	-128	40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay	-128	40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter	-128	40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN	-128	40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray	-128	40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice	-128	40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA	-128	40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud	-128	40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD	-128	40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI	-128	40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP	-128	40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP	-128	40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink	-128	40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP	-128	40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB	-3	40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice	-128	40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM	-128	40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep	-128	40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging	-128	40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen	-128	40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning	-128	40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav	-128	40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS	-128	40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online	-128	40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal	-128	40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI	-128	40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN	-128	40
IDE10480-MAS10741-Interface for external media: activation-Connection 1	activated 	4
IDE10480-MAS10742-Interface for external media: activation-Connection 2	not activated 	4
IDE10480-MAS10743-Interface for external media: activation-Connection 3	not activated 	4
IDE10480-MAS10744-Interface for external media: activation-Connection 4	not activated 	4
IDE10604-Menu entries for mobile online services	not activated 	1
IDE11122-Country identification: country of sale HMI	US 	2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0	non_blocked 	21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1	non_blocked 	21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10	non_blocked 	21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11	non_blocked 	21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12	non_blocked 	21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13	non_blocked 	21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14	non_blocked 	21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15	non_blocked 	21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16	non_blocked 	21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17	non_blocked 	21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18	non_blocked 	21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19	non_blocked 	21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2	non_blocked 	21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20	non_blocked 	21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21	non_blocked 	21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22	non_blocked 	21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23	non_blocked 	21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3	non_blocked 	21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4	non_blocked 	21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5	non_blocked 	21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6	non_blocked 	21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7	non_blocked 	21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8	non_blocked 	21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9	non_blocked 	21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0	non_blocked 	21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1	non_blocked 	21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10	non_blocked 	21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11	non_blocked 	21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12	non_blocked 	21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13	non_blocked 	21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14	non_blocked 	21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15	non_blocked 	21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16	non_blocked 	21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17	non_blocked 	21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18	non_blocked 	21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19	non_blocked 	21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2	non_blocked 	21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20	non_blocked 	21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21	non_blocked 	21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22	non_blocked 	21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23	non_blocked 	21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3	non_blocked 	21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4	non_blocked 	21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5	non_blocked 	21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6	non_blocked 	21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7	non_blocked 	21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8	non_blocked 	21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9	non_blocked 	21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0	non_blocked 	21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1	non_blocked 	21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10	non_blocked 	21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11	non_blocked 	21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12	non_blocked 	21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13	non_blocked 	21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14	non_blocked 	21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15	non_blocked 	21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16	non_blocked 	21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17	non_blocked 	21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18	non_blocked 	21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19	non_blocked 	21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2	non_blocked 	21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20	non_blocked 	21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21	non_blocked 	21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22	non_blocked 	21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23	non_blocked 	21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24	non_blocked 	21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25	non_blocked 	21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26	non_blocked 	21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27	non_blocked 	21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28	non_blocked 	21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29	non_blocked 	21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3	non_blocked 	21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30	non_blocked 	21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31	non_blocked 	21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32	non_blocked 	21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33	non_blocked 	21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34	non_blocked 	21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35	non_blocked 	21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36	non_blocked 	21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37	non_blocked 	21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38	non_blocked 	21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39	non_blocked 	21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4	non_blocked 	21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40	non_blocked 	21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41	non_blocked 	21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42	non_blocked 	21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43	non_blocked 	21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44	non_blocked 	21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45	non_blocked 	21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46	non_blocked 	21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47	non_blocked 	21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5	non_blocked 	21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6	non_blocked 	21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7	non_blocked 	21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8	non_blocked 	21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9	non_blocked 	21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0	non_blocked 	21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1	non_blocked 	21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10	non_blocked 	21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11	non_blocked 	21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12	non_blocked 	21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13	non_blocked 	21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14	non_blocked 	21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15	non_blocked 	21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16	non_blocked 	21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17	non_blocked 	21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18	non_blocked 	21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19	non_blocked 	21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2	non_blocked 	21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20	non_blocked 	21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21	non_blocked 	21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22	non_blocked 	21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23	non_blocked 	21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24	non_blocked 	21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25	non_blocked 	21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26	non_blocked 	21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27	non_blocked 	21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28	non_blocked 	21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29	non_blocked 	21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3	non_blocked 	21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30	non_blocked 	21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31	non_blocked 	21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32	non_blocked 	21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33	non_blocked 	21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34	non_blocked 	21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35	non_blocked 	21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36	non_blocked 	21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37	non_blocked 	21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38	non_blocked 	21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39	non_blocked 	21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4	non_blocked 	21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5	non_blocked 	21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6	non_blocked 	21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7	non_blocked 	21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8	non_blocked 	21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9	non_blocked 	21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0	non_blocked 	21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1	non_blocked 	21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10	non_blocked 	21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11	non_blocked 	21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12	non_blocked 	21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13	non_blocked 	21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14	non_blocked 	21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15	non_blocked 	21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2	non_blocked 	21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3	non_blocked 	21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4	non_blocked 	21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5	non_blocked 	21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6	non_blocked 	21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7	non_blocked 	21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8	non_blocked 	21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9	non_blocked 	21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0	non_blocked 	21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1	non_blocked 	21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10	non_blocked 	21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11	non_blocked 	21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12	non_blocked 	21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13	non_blocked 	21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14	non_blocked 	21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15	non_blocked 	21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2	non_blocked 	21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3	non_blocked 	21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4	non_blocked 	21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5	non_blocked 	21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6	non_blocked 	21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7	non_blocked 	21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8	non_blocked 	21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9	non_blocked 	21
IDE11503-Satellite radio tuner: pre-activated subscription	7	1
MAS00951-Bluetooth	On 	1
MAS01968-Fan	normal 	1
MAS02809-MAS02870-Check tone frequency-High note frequency range	4000 Hz	6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range	1000 Hz	6
MAS02809-MAS02872-Check tone frequency-Low note frequency range	100 Hz	6
MAS03782-WLAN	On 	1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization	not activated 	60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer	not activated 	60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off	not activated 	60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high	not activated 	60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill	not activated 	60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation	not activated 	60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer	not activated 	60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off	not activated 	60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high	not activated 	60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill	not activated 	60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent	not activated 	60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer	not activated 	60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off	not activated 	60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high	not activated 	60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill	not activated 	60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC	not activated 	60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer	not activated 	60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off	not activated 	60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high	not activated 	60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill	not activated 	60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key	not activated 	60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer	not activated 	60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off	not activated 	60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high	not activated 	60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill	not activated 	60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue	not activated 	60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer	not activated 	60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off	not activated 	60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high	not activated 	60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill	not activated 	60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper	not activated 	60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer	not activated 	60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off	not activated 	60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high	not activated 	60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill	not activated 	60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination	activated 	60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer	not activated 	60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off	not activated 	60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high	activated 	60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill	not activated 	60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope	not activated 	60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer	not activated 	60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off	not activated 	60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high	not activated 	60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill	not activated 	60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification	not activated 	60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer	not activated 	60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off	not activated 	60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high	not activated 	60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill	not activated 	60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating	not activated 	60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer	not activated 	60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off	not activated 	60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high	not activated 	60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill	not activated 	60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv	not activated 	60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer	not activated 	60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off	not activated 	60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high	not activated 	60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill	not activated 	60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management	not activated 	60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer	not activated 	60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off	not activated 	60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high	not activated 	60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill	not activated 	60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE	activated 	60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer	not activated 	60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off	not activated 	60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high	activated 	60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill	not activated 	60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer	activated 	60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer	not activated 	60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off	not activated 	60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high	activated 	60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill	not activated 	60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function	activated 	60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer	not activated 	60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off	not activated 	60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high	activated 	60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill	not activated 	60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror	activated 	60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer	not activated 	60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off	not activated 	60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high	activated 	60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill	not activated 	60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking	activated 	60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer	not activated 	60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off	not activated 	60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high	activated 	60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill	not activated 	60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master	activated 	60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer	not activated 	60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off	not activated 	60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high	activated 	60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill	not activated 	60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma	activated 	60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer	not activated 	60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off	not activated 	60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high	activated 	60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill	not activated 	60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration	activated 	60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer	not activated 	60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off	not activated 	60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high	activated 	60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill	not activated 	60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock	activated 	60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer	not activated 	60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off	not activated 	60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high	activated 	60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill	not activated 	60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass	not activated 	60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer	not activated 	60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off	not activated 	60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high	not activated 	60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill	not activated 	60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist	not activated 	60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer	not activated 	60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off	not activated 	60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high	not activated 	60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill	not activated 	60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration	not activated 	60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer	not activated 	60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off	not activated 	60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high	not activated 	60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill	not activated 	60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school	not activated 	60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer	not activated 	60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off	not activated 	60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high	not activated 	60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill	not activated 	60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall	activated 	60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer	not activated 	60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off	not activated 	60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high	activated 	60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill	not activated 	60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist	not activated 	60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer	not activated 	60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off	not activated 	60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high	not activated 	60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill	not activated 	60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI	activated 	60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer	not activated 	60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off	not activated 	60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high	activated 	60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill	not activated 	60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination	activated 	60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer	not activated 	60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off	not activated 	60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high	activated 	60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill	not activated 	60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display	not activated 	60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer	not activated 	60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off	not activated 	60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high	not activated 	60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill	not activated 	60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid	not activated 	60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer	not activated 	60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off	not activated 	60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high	not activated 	60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill	not activated 	60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant	activated 	60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer	activated 	60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off	not activated 	60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high	activated 	60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill	activated 	60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning	activated 	60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer	not activated 	60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off	not activated 	60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high	activated 	60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill	not activated 	60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker	not activated 	60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer	not activated 	60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off	not activated 	60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high	not activated 	60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill	not activated 	60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision	not activated 	60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer	not activated 	60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off	not activated 	60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high	not activated 	60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill	not activated 	60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level	not activated 	60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer	not activated 	60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off	not activated 	60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high	not activated 	60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill	not activated 	60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc	not activated 	60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer	not activated 	60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off	not activated 	60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high	not activated 	60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill	not activated 	60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist	not activated 	60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer	not activated 	60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off	not activated 	60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high	not activated 	60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill	not activated 	60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk	activated 	60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer	not activated 	60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off	not activated 	60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high	activated 	60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill	not activated 	60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment	not activated 	60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer	not activated 	60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off	not activated 	60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high	not activated 	60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill	not activated 	60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load	not activated 	60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer	not activated 	60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off	not activated 	60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high	not activated 	60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill	not activated 	60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification	not activated 	60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer	not activated 	60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off	not activated 	60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high	not activated 	60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill	not activated 	60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration	not activated 	60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer	not activated 	60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off	not activated 	60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high	not activated 	60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill	not activated 	60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic	not activated 	60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer	not activated 	60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off	not activated 	60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high	not activated 	60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill	not activated 	60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia	activated 	60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer	not activated 	60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off	not activated 	60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high	activated 	60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill	not activated 	60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view	activated 	60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer	not activated 	60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off	not activated 	60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high	activated 	60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill	not activated 	60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions	not activated 	60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer	not activated 	60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off	not activated 	60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high	not activated 	60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill	not activated 	60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler	not activated 	60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer	not activated 	60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off	not activated 	60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high	not activated 	60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill	not activated 	60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI	not activated 	60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer	not activated 	60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off	not activated 	60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high	not activated 	60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill	not activated 	60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons	not activated 	60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer	not activated 	60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off	not activated 	60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high	not activated 	60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill	not activated 	60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant	not activated 	60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer	not activated 	60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off	not activated 	60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high	not activated 	60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill	not activated 	60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner	not activated 	60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer	not activated 	60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off	not activated 	60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high	not activated 	60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill	not activated 	60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo	not activated 	60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer	not activated 	60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off	not activated 	60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high	not activated 	60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill	not activated 	60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating	activated 	60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer	not activated 	60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off	not activated 	60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high	activated 	60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill	not activated 	60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin	activated 	60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer	not activated 	60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off	not activated 	60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high	activated 	60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill	not activated 	60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition	not activated 	60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer	not activated 	60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off	not activated 	60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high	not activated 	60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill	not activated 	60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows	activated 	60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer	not activated 	60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off	not activated 	60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high	activated 	60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill	not activated 	60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper	activated 	60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer	not activated 	60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off	not activated 	60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high	activated 	60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill	not activated 	60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol	not activated 	60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer	not activated 	60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off	not activated 	60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high	not activated 	60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill	not activated 	60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05	not activated 	64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus	Databus extended 	64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06	not activated 	64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus	Suspension data bus 	64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D	not activated 	64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus	not activated 	64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24	not activated 	64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus	not activated 	64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03	not activated 	64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus	Comfort data bus 	64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B	not activated 	64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus	Terminal 15 	64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25	not activated 	64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus	Databus drivetrain 	64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23	activated 	64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus	Databus Infotainment 	64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26	activated 	64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus	Suspension data bus 	64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D	activated 	64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus	Comfort data bus 	64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17	activated 	64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus	Databus Infotainment 	64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16	not activated 	64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus	Comfort data bus 	64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01	activated 	64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus	Comfort data bus 	64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02	not activated 	64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus	Comfort data bus 	64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11	activated 	64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus	Comfort data bus 	64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15	not activated 	64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus	not activated 	64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10	not activated 	64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus	Comfort data bus 	64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33	activated 	64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus	Comfort data bus 	64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C	Comfort data bus 	64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C	not activated 	64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37	activated 	64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus	Comfort data bus 	64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38	not activated 	64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus	Comfort data bus 	64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09	activated 	64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus	Comfort data bus 	64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04	not activated 	64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus	Comfort data bus 	64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D	not activated 	64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus	Databus drivetrain 	64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08	activated 	64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus	Comfort data bus 	64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19	not activated 	64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus	Databus extended 	64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F	activated 	64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus	Comfort data bus 	64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34	not activated 	64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34	Databus Infotainment 	64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E	activated 	64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus	Comfort data bus 	64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18	not activated 	64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus	not activated 	64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A	not activated 	64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus	Terminal 15 	64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20	not activated 	64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus	Comfort data bus 	64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A	not activated 	64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A	Databus extended 	64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39	not activated 	64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39	Databus Infotainment 	64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E	not activated 	64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus	Comfort data bus 	64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F	not activated 	64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus	Databus drivetrain 	64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B	not activated 	64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B	Comfort data bus 	64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F	not activated 	64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F	Comfort data bus 	64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E	not activated 	64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E	Comfort data bus 	64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12	activated 	64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus	Comfort data bus 	64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E	activated 	64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus	Databus extended 	64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35	not activated 	64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35	Comfort data bus 	64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27	not activated 	64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus	Databus Infotainment 	64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A	activated 	64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus	Databus extended 	64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07	activated 	64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus	Suspension data bus 	64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21	not activated 	64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus	Databus extended 	64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36	not activated 	64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36	Comfort data bus 	64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C	not activated 	64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus	Comfort data bus 	64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14	not activated 	64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus	Terminal 15 	64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13	activated 	64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus	Comfort data bus 	64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B	not activated 	64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus	Databus Infotainment 	64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22	not activated 	64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus	Databus Infotainment 	64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C	activated 	64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus	Comfort data bus 	64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key	Not available 	8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus	Comfort data bus 	8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school	Not available 	8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus	Databus Infotainment 	8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL	Available 	8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus	Databus Infotainment 	8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level	Not available 	8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus	Databus drivetrain 	8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering	Not available 	8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus	Suspension data bus 	8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved	Not available 	8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1	Comfort data bus 	8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2	Comfort data bus 	8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3	Not available 	8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN	Available 	8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus	Comfort data bus 	8
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1	0	6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2	50	6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3	100	6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1	0	6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2	50	6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3	100	6
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1	0	6
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2	50	6
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3	100	6
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1	0	6
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2	50	6
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3	100	6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1	0	12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2	10	12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3	100	12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4	150	12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5	220	12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6	253	12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1	1%	12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2	1%	12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3	8%	12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4	20%	12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5	60%	12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6	100%	12
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation	04 01 52 04 52 10 52 40 52 32 00 64 00 3C 00 7C 01 1D 01 50 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 02 00 A8 	40
ENG117809-p_damping_Display	5 ms	1
ENG117808-p_HMI_Display	13%	1
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset	0	2
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset	0	2
ENG117919-Startup_Screen_Sticker_HMI	00 01 	2
Elapsed Time: 00:38
MasterTommy
Amsterdam
C?ID=295586
Some screens of long coding helper of bytes I believe are relevant to the AID:
5F:
17 - Instruments
9900rpm
C?ID=83902
Anyone know the bytes and bits for speedometer? Mine still reads about 10mph higher than it should. I’m assuming it’s going by Tiguan or Toureg wheels size and not GTI.
Also, need to know the bytes and bits to change the graphics on this thing. It’s still the SUV instead of a GTI picture when doors are open.
Thanks in advance.
9900rpm
C?ID=83902
Bump.
Got the cluster face to change (fonts, look, and from 160 to 180 and also to 200mph speedo). Still looking for help on changing the car icon to a GTI from a Tiguan, and also to make the speedometer read correctly, as it still reads about 10mph high).
Also, I will be installing a MOST optical cable between the cluster and MIB2. Will that make the navigation maps show on the cluster? (does it even work with the MIB2 to cluster that way)? Also, if it does, is there anything I need to code to make this work?
TIA.
MasterTommy
Amsterdam
C?ID=295586
Yeah, map is streamed over MOST to AID. I posted the coding of my tiguan (which probably uses the same protocols) a few posts earlier. If you copy any message protocol/MOST related bits, that should give you a good baseline. The car model is also in coding, will post a screen of the right byte when I get home.
9900rpm
C?ID=83902
Cool, I’ll Wait for that.
My GTI has the MIB2 head unit. Does it support the navigation graphics for the cluster? Friend of mine said that it might not. There’s not much info on this topic out there. He did say that the 5F in the big screen newer GTIs have things that the MIB2 cars do not (not sure if it’s true or he just doesn’t know what he’s talking about).
vastechnics
C?ID=143747
It's for as far I know impossible to change the Tiguan car to GTI (Golf). Have retrofitted this lot of time, but the car stays te same. If you have DP MIB2 3G0 partnumber the Navi will work on the display. This because Passat B8 with DP MIB2 3G0 also comes with AID, and works also so.
MasterTommy
Amsterdam
C?ID=295586
I went through one of the coding drop-down menu bits once, and i could get it to swap between tiguan and tiguan allspace. The question is how many models it supports.
