Audi A1 limp mode after start up
colin41
C?ID=242997
Audi A1 that drops into limp mode shortly after startup when cold but fine when warm.
VIN: WAUZZZ8X0CB212311   License Plate:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F
VIN: WAUZZZ8X0CB212311   Mileage: 103730km-64454miles
   Part No SW: 03L 906 023 KQ    HW: 03L 906 023 KP
   Component: R4 1.6l TDI   H63 9978
   Revision: --H63---    Serial number:
   Coding: 00114016030501080000
   Shop #: WSC 00046 790 00000
   ASAM Dataset: EV_ECM16TDI02103L906023KQ 003015
   ROD: EV_ECM16TDI02103L906023KG.rod
   VCID: 7F0A99A5E6176FBEE8-802A
10117 - Fuel Pressure Regulation Valve 2 Control Difference
          P229B 00 [167] - Pressure too High
                    Mileage: 103732 km
                    Date: 2017.12.16
                    Time: 16:06:30
                    Engine speed: 990.75 /min
                    Normed load value: 32.9 %
                    Coolant temperature: 7 °C
                    Intake air temperature: 5 °C
                    Voltage terminal 30: 14.118 V
                    Fuel high pressure: actual value-FUP_FIL: 35.675 MPa
                    Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
                    Engine status-SF_ENG_STATE: IS
                    Fuel temperature-TFU: 6 °C
                    Fuel Metering Valve-VCV: 24.918 %
                    Fuel Pressure Regulator Valve-PCV: 0.000 %
                    Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 25592.041 kPa
   Part No SW: 6R0 907 379 BB    HW: 6R0 907 379 AH
   Component: ESP8.2i front H07 0001
   Revision: --------
   Coding: 330448E9436E00B4CC2812E3C2D200920C00
   Shop #: WSC 00046 000 00000
   VCID: 7F0A99A5EA176FBEE8-802A
   Part No SW: 8X0 820 045 A    HW: 8X0 820 045 A
   Component: J255 Klima Manuell  0140
   Revision: 0000707S    Serial number: 03030006789104
   VCID: 3460868957D17CE645-8060
   Part No SW: 8X0 907 063 G    HW: 8X0 907 063 G
   Component: BCM PQ35  M   110 0655
   Revision: 00110 AE
   Coding: 0E000A2CA805F100201841E000000154438B6C0A00CF4122DC0087830041
   VCID: 4088DA59D369D046D1-8014
   Subsystem 1 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 208
                    Mileage: 87361 km
                    Date: 2017.02.10
                    Time: 12:59:16
                        Term 15 Off
                    Voltage: 13.45 V
                        Term 50 Off
   Part No SW: 8X0 959 655 B    HW: 8X0 959 655 B
   Component: Airbag10.41   H05 0009
   Revision: --------    Serial number: 003KZ000C9YR
   Coding: 30314539303330303034554A305238583053
   ASAM Dataset: EV_Airba1041BPAAU210 001018
   ROD: EV_Airba1041BPAAU210.rod
   VCID: 499EC77DE853110E06-801C
   Serial number: 3554VRB405N0U2UUFGVE
   Serial number: 3575HRB406114JQMAP0L
   Serial number: 3585HRB405J14JQM6G4U
   Rear Impact Crash Sensor:
   Serial number: 3515ZRB405B0QMN2AHD5
   Part No SW: 8X0 953 501 B    HW: 5K0 953 569 H
   Revision: FF010016    Serial number: 20120204100023
   Coding: 1184004000
   VCID: 397EB7BDB8B3818E96-806C
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H08 0009
Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb
   Part No SW: 8X0 920 980 D    HW: 8X0 920 980 D
   Component: KOMBI_MEDIUM  H03 0180
   Coding: 41DE00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
   VCID: 4088DA59DB69D046D1-8014
   Part No SW: 8U0 907 468 A    HW: 8U0 907 468 A
   Component: GAT 4CAN 1L M H10 0044
   Revision: 1P040023    Serial number: 2341P1212802B6
   Coding: FBCF005A000100010153
   Subsystem 1 - Part No SW: 8K0 915 181 H    HW: 8K0 915 181 H
   Component: J367-BDM  H07 0171
   Serial number: 00000000007100327882
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 02121100000000000267
   Component: IMMO          H03 0180
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8X0 959 793 B    HW: 8X0 959 793 B
   Component: TSG FA        H09 0409
   Coding: 011802200101000100
   VCID: 4C90FE69EF2104263D-8018
   Part No: 6R0 423 156 B
   Coding: 11251
   Shop #: WSC 00046
   VCID: 2F6A89E5EAF75F3E38-807A
   Part No SW: 8X0 959 792 B    HW: 8X0 959 792 B
   Component: TSG BF        H09 0409
   VCID: 4B92FD75EA2F031E34-801E
   Part No SW: 8X0 035 183 E    HW: 8X0 035 183 D
   Component: RMC Cnct      H52 0775
   Coding: 01010000000051070023000103010000010000
   VCID: 397EB7BDB0B3818E96-806C
   Subsystem 1 - Part No SW: 8X0 919 603     HW: 8X0 919 603
   Component: DU6 Basic  H42 0084
   Serial number: 9462AK0C2520731
Gone But Not Forgotten
Yeah the dump control PSI valve is sticking and when fuel is cold it is thicker so it can do this more raising the PSI.
Run some additives through with added lubricity or take apart and clean and polish everything!
1 cup of gasoline goes a long way mixed with fuel.
colin41
C?ID=242997
thank you sir. it has only started so hopefully additives will help it.
if not what valve is the fault code referring to? FPR in the rail?
colin41
C?ID=242997
just thought id come back to this. Used fuel additives and seems to have cured the problem.
A fun read and never gets old for me..........
https://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM475595/INCR-EA11003-61863.pdf
Vehicle testing.
Volkswagen conducted vehicle testing with varying amounts of gasoline
misfueling to study the effects on engine performance and HPFP wear. The tests showed that
increased levels of gasoline will lead to driveability symptoms, such as engine stumbling, stuttering,
misfiring or rough running. According to Volkswagen, these symptoms start to become noticeable
at levels of gasoline misfueling of 50 percent. At levels of 80 percent
4 and above, Volkswagen
indicated that driveability issues worsen until the diesel engine will no longer run due to the
interruption of the combustion process. At very high levels of misfueling (80-85%), test vehicles
exhibited obvious knocking noise within a few seconds after starting the vehicle and showed a
significant reduction in engine response and transition to limp mode operation in less than a mile
after attempting to accelerate to highway speeds. No performance problems were observed in 378
miles of test driving a vehicle with 5% gasoline added to the diesel fuel and Volkswagen has
indicated that operation with small amounts of gasoline contamination should have no effect on
HPFP durability. No damage to the HPFP’s were observed by Volkswagen after misfuel tests with
either low or high amounts of gasoline misfueling.
Pump failure effects.
ODI evaluated the effects of HPFP drivetrain failure on engine performance
by: 1) reviewing Volkswagen’s descriptions of the failure mechanism and effects; 2) analyzing ODI
complaint narratives combined with follow-up interviews, when necessary; 3) analyzing diagnostic
data retrieved by Volkswagen from some ODI complaint vehicles; and 4) reviewing the results of
Volkswagen testing of a vehicle with a pre-damaged pump roller.
5
According to Volkswagen, drivetrain wear results in gradual reductions in fuel pressure due to
decreased pump plunger displacement. In addition, as wear progresses metal is abraded from
drivetrain surfaces forming small flakes that are circulated throughout the fuel system. Particles
caught in the metering unit strainer cause a pressure drop, which results in a fault code and warning
light. Volkswagen states that the rate of wear “depends on the properties of fuel being used as well
as pump load conditions.” Several of the pump failures in parts returned to ODI, or documented
during inspections by Bosch or by some consumers, displayed failures caused by rollers rotating 90
degrees relative to the cam, resulting in a distinct abrasive wear pattern in the center of the cam.
Figure 8 shows the Bosch self-stabilizing design and drivetrain damage resulting from roller
rotation in an ODI complaint vehicle that reported experiencing a sudden decrease in engine power
resulting in speed dropping from 70 mph to 50 mph, as the vehicle entered limp mode less than a
minute after the engine light and then glow plug lamp illuminated (VOQ 10354434).
4
Volkswagen indicated that a fuel tank mixture of 80% gasoline and 20% diesel would result from refueling with
gasoline shortly after the low fuel warning light has illuminated.
5
As previously noted, Volkswagen was not able
