MK6 Golf Edition 35 Lost ABS Coding - Race Car
iichel
Netherlands, eastern part
C?ID=284912
oh well, try this first. then we'll finetune. the first step is to get the code accepted.
   #22
pronet
Romania
C?ID=157414
Ok. Roger that. Thanks a lot. As soon as I get the feedback I 'll post here.
   #23
pronet
Romania
C?ID=157414
So the message returned: VCDS has detected a chanfge in coding length. If I press yes to continue - codding rejected error 12. If he erased the last 2 digits - error 31, codding rejected.
   #24
iichel
C?ID=284912
WVWZZZ1KZ9P009260
2009 MK 6 golf
LHD
FWD
Manual gearbox
2.0 TDI
312/253mm brakes?
TPMS no
normal ESP deactivation
000000000000000000000000000000000000 Empty
114B000C09220003880D00EA901900000000
114B600C09220003880D06EA90190042040C rejected
   #25
pronet
Romania
C?ID=157414
The car is not MK VI. Is MK V, GT.
   #26
iichel
C?ID=284912
Ah okay, luckily that doesn't matter since they both have the 1K chassis :-)
   #27
wiktor0410
C?ID=87753
Hello everyone, greetings from Poland!
I own an 2010 MK6 GTI from US and I am facing a similar issue. Since I don't want to create new topic, I decided to ask here. The thing is, my car (other than MNZ's) is not a race car - just my daily driver. When I purchased it, 03-ABS module long coding consisted of a bunch of "0". Thanks to Ross-Tech customer support, we have managed to successfully code the pump. However, there is 03756 - ESP De-Activated DTC and I don't know how to get rid of that. There is also an "ESP off." pop-up on VIS after turning the ignition on and airbag MIL comes on (which is not the concern since the two issues are very likely to be correlated). Obviously I would like to return the ESP functionality, since the car is vary hard to drive in wet/snowy conditions.
I also asked my PL fellows on MK6 GTI group about the issue (since MNZ's car was from PL) but noone can help.
Auto-scan below (please ignore 01-Engine malfunctions - I am getting the downpipe and lambda sensors issue sorted out next week). Any help or idea would be much appreciated. Thanks in advance!
Wednesday,10,January,2018,16:45:04:26663
VCDS Version: 17.8.1.0 (x64)
www.Ross-Tech.com <http://www.Ross-Tech.com>
VIN: WVWED7AJ6AW224978   License Plate:
Mileage: 90150km-56016mi   Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 55 56 77
VIN: WVWED7AJ6AW224978   Mileage: 90150km-56016miles
   Part No SW: 1K0 907 115 AL    HW: 1K0 907 115 AK
   Revision: E3H21---    Serial number:
   Coding: 0403010818070160
   VCID: 70E4279F63CB34C661-8024
000066 - Oxygen (Lambda) Sensor B1 S3: Heating Circuit
               P0042 - 000 - Malfunction /Open Circuit - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 116
                    Mileage: 88672 km
                    Date: 2012.05.04
                    Time: 13:39:21
                    RPM: 5228 /min
                    Load: 96.0 %
                    Speed: 179.0 km/h
                    Temperature: 95.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.970 V
008342 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
               P2096 - 000 - Too Lean
                    Mileage: 90063 km
                    Date: 2012.05.31
                    Time: 16:19:20
                    RPM: 2316 /min
                    Load: 34.1 %
                    Speed: 47.0 km/h
                    Temperature: 60.0°C
                    Temperature: 4.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.224 V
000067 - Oxygen (Lambda) Sensor B1 S3: Heating Circuit
               P0043 - 000 - Short to Ground - Intermittent
                    Mileage: 90070 km
                    Date: 2012.06.01
                    Time: 07:08:02
                    RPM: 883 /min
                    Load: 34.9 %
                    Temperature: 4.0°C
                    Temperature: -1.0°C
                    Voltage: 14.224 V
Readiness: 0010 0001
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Revision: 00H30001
   Coding: 114B600C492400FE881406EB92210041300800
   VCID: 78F41FBFCBBB6C86A9-802C
01487 - System Function Test
            000 -  -  - Intermittent
                    Reset counter: 37
                    Mileage: 90147 km
                    Date: 2012.06.02
                    Time: 16:35:53
                    Count: 4
                    Count: 4608
                    Count: 321
                    Count: 50688
                    Count: 5376
            000 -  -
                    Reset counter: 37
                    Mileage: 90146 km
                    Date: 2012.06.02
                    Time: 16:32:55
                    Count: 1
                    Count: 2
                    Count: 12800
                    Count: 320
                    Count: 50944
            000 -  -
                    Reset counter: 37
                    Mileage: 90146 km
                    Date: 2012.06.02
                    Time: 16:33:04
                    Count: 5
                    Count: 2
                    Count: 12800
                    Count: 394
                    Count: 50944
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000001002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75EA168BD4A911EEB2-8020
   Part No SW: 1K0 937 087 G    HW: 1K0 937 087 G
   Component: BCM PQ35  H+  103 0576
   Revision: 00103 AE
   Coding: 67180A3E98332A04404A00857400892447E50080435D8D20648828240000
   Shop #: WSC 63351 123 12345
   VCID: 356AD68B9C2951EE72-8060
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 09110  21  0512
   Coding: 009795
                    Fault Frequency: 8
                    Reset counter: 233
                    Mileage: 86159 km
                    Date: 2012.01.07
                    Time: 09:42:39
                        Term 15 On
                    Voltage: 12.05 V
                        Term 50 On
02661 - Wire for Speed Signal
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 45
                    Mileage: 86858 km
                    Date: 2012.01.23
                    Time: 15:13:39
                        Term 15 On
                    Voltage: 13.80 V
                        Term 50 On
                    Fault Status: 00101110
                    Reset counter: 77
                    Mileage: 90146 km
                    Date: 2012.06.02
                    Time: 16:21:30
                        Term 15 On
                    Voltage: 11.60 V
                        Term 50 On
03384 - Windshield Washer Jet Heating
                    Reset counter: 79
                    Mileage: 87284 km
                    Date: 2012.02.14
                    Time: 09:43:07
                        Term 15 On
                    Voltage: 14.15 V
                        Term 50 On
01134 - Alarm Horn (H12)
                    Fault Status: 01101100
                    Reset counter: 134
                    Mileage: 87994 km
                        Term 15 Off
                    Voltage: 12.45 V
                        Term 50 Off
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4D0A0GU2
   Coding: 00003031
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3972DABBB831B58E96-806C
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--0004WNYA00
   Serial number: 3572MSME2F47614DZZZ2
   Serial number: 3582MSME0F04264DZZZ
   Serial number: 3512QSME221B3D05ZZZS
   Serial number: 3522QSME082D401CZZZW
   Serial number: 35527SME3E670E1FZZZ-
   Serial number: 35627SME5E5D532BZZZZ
9483008 - Seat Occupied Recognition
          B10B3 00 [137] - Function Restriction due to Implausible Message(s)
                    Reset counter: 38
                    Mileage: 90146 km
                    Date: 2018.01.10
                    Time: 16:29:16
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Coding: 0000532
   VCID: 78F41FBF0BBB6C86A9-802C
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Part No SW: 5K6 920 970 H    HW: 5K6 920 970 H
   Component: KOMBI         H03 0305
   Coding: 170D00
   Component: J533  Gateway   H16 0231
   Revision:   H16       Serial number: 4320K09B180451
   Coding: E9811F06001612000000
   VCID: 69D24AFB4011C50E26-803C
   Revision: 00001000    Serial number: 1225223T6MKY04
   VCID: 7EF809A7299F52B6E3-802A
   Component: IMMO          H03 0305
   VCID: 6AD035F78D17CE162F-803E
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667670201
   VCID: 264801C7518F2A76CB-8072
   Component: Tuer-SG         009 2111
   Coding: 0001076
   VCID: 3162E29BA8417DCE2E-8064
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
   Coding: 0001076
   VCID: 3260ED97AD4746D657-8066
   Component: AFS-Steuergeraet    0142
   Coding: 1446940
   VCID: 346CEB8F575348E645-8060
   Coding: 00000022
   Coding: 00000022
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0035
   Revision: -----20S    Serial number: VWZ4Z7J1129597
   Coding: 0100040004
   VCID: 61C252DB78218D4EFE-8034
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 216
                    Reset counter: 223
                    Mileage: 86812 km
                    Date: 2012.01.21
                    Time: 18:05:15
02633 - Antenna for Satellite Tuner
                    Fault Status: 00100111
                    Reset counter: 78
                    Mileage: 90146 km
                    Date: 2012.06.02
                    Time: 16:23:40
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 C    HW: 1K8 035 730 C
   Component: Telefon       H08 6600
   Revision: 00008000    Serial number: 20389520288527
   Coding: 412100
   VCID: 29520AFB4091050EE6-807C
End-------------------------(Elapsed Time: 02:04)--------------------------
wiktor0410
C?ID=87753
Tried to perform, but the test can't even be initiated, most likely due to the 03756 DTC:
Prerequisites
The ONLY fault that should be stored in the 03-ABS controller is 01486 and the 44-Steering Assist module should be fault-free.
Also, there is no warning light on the dash after pressing the brake pedal to begin the Test...
   #30
Dana
Western PA, USA
Hi guys,
I built that ABS coding but I'm not entirely confident this (NAR market) vehicle was born with that 19 Byte ABS module. Any comments/suggestions related to coding are welcome. The baseline (zeroed VIN Bytes) info we have for 2010 NAR GTIs with the engine CBFA 2.0T code are
19 Byte coding (which I used):
11006000490000008800060092000041300800
18 Byte:
11006000C90000008800060093000041B108​
Wiktor,
Per the Adp map you sent we spotted Adp channel 090 is disabled:
90 0 ESP Off N/A N/A N/A
If you can't simply change that from 0 (off) to 1 (on) please ping me back via email and we can experiment with some SA codes.
   #31
wiktor0410
C?ID=87753
Channel 090 in adaptation changed to "1", but after saving and reading again it returns to "0".
   #32
Dana
Western PA, USA
Wiktor and I have been working via email and this isn't sorted yet. ESP insists on staying OFF and I believe that's why his System Function Test drive attempts have failed.
He can get Adp channel 090 to turn on (1) but that won't stick meaning if flips back to 0. We never assist with ESP deletes (for liability reasons) so I'm at a bit of a loss due to lack of experience even though the goal here is to turn it ON for factory operation.
I gave him some additional SA code suggestions to try and after we get feedback I can update the thread. In the meanwhile, if anyone spots anything suspicious in my coding feel free to post up ideas.
   #33
iichel
C?ID=284912
so it's this coding --> 114B600C492400FE881406EB92210041300800
what happens if you set byte 6 to 08? and make byte 14 the inverse, so 10. byte 16 seems to be ok, HEX 30 = 00110000.
114B600C492408FE881406EB92211041300800
i have no idea whether it will make any difference, but let's see how the module responds.
   #34
:D.................. EDL ............. /\
Electronic Differential Lock
A new cursor hover icon for the forum ..............?
   #38
Dana
Western PA, USA
Thanks guys! He has PR UG3 Comfort driving assist
We have those basic on or off bits broke down in these groups:
LC,16,0,Hill Hold Control (HHC) active/installed [PR-UG1/UG4]
LC,17,3,Extended Electronic Differential Lock (XDS) active [PR-UG3/UG4]
(similar to things like with TPMS) but I see where both of you are going. Wiktor, please try that alternative coding in post #33 and let us know!
   #39
wiktor0410
C?ID=87753
Hi guys!
Thanks for all responses! Unfortunately though, I am still unable to revert ESP functionality. I tried SA codes provided by Dana but with no luck (I cannot change adaptation channel 90 to ON). I also tried coding posted by lichel but it gets refused by the controller (Out of range).
Is it possible that the module is somehow faulty and the only way out is replacing it with a working one? If so, shouldn't be any ABS/ESP MIL's on the dash?
Even though, I believe that we eventually will sort the issue out :)
Regards,
Wiktor
   #40
Vehicle Identification No.WVWED7AJ6AW224978
ModelGolf 2,0 GO
Date of production24.11.2009
Year2010
Sales type5K19W2
Engine CodeCBFA
Transmission CodeKZS
Axle drive6S
Equipment XE
Roof colorG2
Carpet color code
Exterior color / Paint CodeG2 / Y3D
x
Exterior ambient lightingE0AWithout special action equipment
Lockable wheel bolts1PEWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components0HAVehicle class differentiation -1K0/5K0-
tail pipe0P1Rear side exhaust tailpipe
drive-off assistanceUG3Comfort driving assist
Emission standard0GTEmission standard SULEV
Trailer hitch1D0without trailer towing
airbag4UMDriver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
Aktivkohlebehälter / Ottopartikelfilter1E7Activated carbon canister (ORVR), for intensified evaporation system, siphoning device for fueling
Aerials8L6"diversity" window antenna
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Left exterior mirror5SHLeft exterior mirror, flat (US)
Right exterior mirror5RRRight exterior mirror, convex (US)
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WLJack for external audio source
Equipment levelsA8HTop sports equipment
Brake type in rear1KVDisc brakes in rear (Geomet D)
batteriesJ1LBattery 280 A (60 Ah)
Brake type, front1LVDisc brakes in front
Components with special surface6FFExterior mirror housing and various attachments colour coded to vehicle
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0DAssembly kit, USA corresponding vehicle version (not California), various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VMInformation kit in American English
Operating voltage9Z0Operating voltage 12 V
brake wear indicator9U1brake wear indicator
Heated washer nozzles9T1Heated washer nozzles in front
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
"Charism"2H0Without "drive select"
Chrome packageQJ3Chrome package (version 2)
General operating permit, alterationsC33Operating permit, alteration
Roof insert/convertible top3FETilting and sliding glass sunroof with sunbshade
Suspension system in rear1JERear sports shock absorption
Suspension system in frontG05Shock absorption in front
Ski bag3X0without load through system
Insert for the filling up of unleaded fuel/fuel type2G7Filler neck module 1 with insert
Installation differentiation for components0ENInstallation differentiation for transmission MQ 350 -- vehicle components --
Theft protection system7AGElectronic immobilizer with anti-theft alarm system (for USA)
Inserts5MDDecorative aluminum inserts
Scuff plates7M5Without impact protection film for door sill
Park distance control7X0Without park distance control
Electric interface for external use UF8Electric interface for external use
Manufacturing sequence differentiation0FAStandard manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Standard pedestrian protection measures
FußhebelwerkVF1pedal cluster
Headlight activation8K4Separate daytime running lights NAR
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Weight category rear axle0YCWeight range 3 installation control only, no requirement forecast
Weight category front axleL98Suspension range 98 installation control only, no requirement forecast
Base engineTQ24-cyl. petrol engine 2.0 l assembly 06J.B
Luggage netting/pocket on backrest(s)4U5Luggage pockets on backrest
Luggage compartment cover3U4Luggage compartment cover
cruise control system8T2Electronic cruise control system (CCS)
Luggage compartment trim5A7Comfort luggage compartment trim with service lid/snap-on cover
Transmission specificationsG0K6-speed manual transmission
handle for hand brake lever6PChandbrake lever grip (leather)
Rear spoiler5J4Body-colored rear spoiler
Rear window wiper and washer system8M1Rear window wiper washer system with intermittent wipe
Rear seats3NJRear bench seat, not split, split backrest, folding
Heating and air-conditioning system9APClimatic air-conditioning system (semi-automatic)
Headlamps8JFTwin headlamps for driving on the right (gas discharge) w/ integrated high beam (US design)
Customized installationFC0Without individual installation
Interior light in footwell6T1Interior light in footwell
Instrument clustersU5CInstrument cluster, mph speedometer - USA -
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror, dimming
Sticker (customized or special edition)0KAWithout decals and emblems
Body styleK8GHatchback
coolbox1W2Glove compartment cooling system
Climatic zones0Y2Tropical zones
Compass/road sign displayQR1With compass
Booster3T2Three rear head restraints
Head restraints3J2Height-adjustable headrests
Fuel tank treatment2LFFuel tank with special material treatment (coextrusion) with changed protective layer
Fuel quantity for initial filling1Z0Initial standard fuel filling
Fuel systems1A5Petrol injector fuel system (FSI)
Body measures5C1Body measures for increased safety requirements
Radiator grille6KARadiator grille
Rear license plate bracket6P2License plate bracket, rear (NAR)
Front license plate bracket6W3License plate bracket front (small, NAR)
Paint preservative/transit coating5K4Full body cover (shape-adapted system) with additional transport protection measures
Paint coatingFB0standard paint coating
Steering system arrangementL0LLeft-hand drive
Reading lamp8S4Two reading lights front, two rear
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H9Backrest release for front seats with Easy Entry feature
Air duct, front areaVK1Air duct, type 1
Lumbar support7P4Manually adjustable lumbar support in front seats
steering wheels2FJLeather-wrapped multi-function sports steering wheel
Speaker installation8RM8 speakers (passive)
Headlight-range adjustment8Q5Headlight range control, autom./dynamic with cornering light (AFS 1)
Center armrest6E3Front center armrest
Marten repellerUM0Without marten repeller
Multi-function display/trip computer9Q5Multi-function display with control
Engine cooling8Z6Hot country
Engine specificationsD2L4-cylinder petrol engine 2.0 L/147 KW (16 V) Turbo FSI, homogeneous Basic engine is: T59/T61/TQ2/TU2/TD6/TN6
Left vanity mirror4SHLeft vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
Right vanity mirror4THVanity mirror, right, illuminated, with cover and special mirror imprint (NAR), extractable
Navigation device7Q0without navigation system
rear fog lamp8TAwitout rear fog lamp
Front fog lamp/additional headlamp8WDIntegrated front fog light
Upgrading measuresGP1Vehicles with special upgrade measures
Rear of platform module base4P0Rear floor panel module, type 1
Platform group class7PAPlatform group class 1
Hubcaps1NLTrims for alloy wheels
WheelsCG6Alloy wheels 7.5J x 17
Radios8AXRadio Premium 8
Smoker's/non-smoker's package9JFNon-smoking package (NAR)
Tire pressure monitoring system7K4Tire pressure monitoring system 315 MHz High
tireH7KAll-season tires 225/45 R17 91H (NAR)
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G1Space-saving spare wheel
Restraint systems, front4QQ3-point seat belts in front with pretensioner and height adjustment, US label
P72California emission concept
P83Xenon package
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q6Gearshift knob/handle in aluminum
Special labels/plates0SSLabels in English and French
Tail lamp assemblies8SDTaillight assembly w/ red colored lens
System torque (Nm)4E0Tailgate/trunk lid unlocking from outside
Front seat, left3TGSports comfort seat in front, left
Front seat, right3SGSports comfort seat, front, right
Nameplates for sales nameQD0Without lettering for sales name
Seat belt check9P7Visual and acoustic seat belt reminder, electric contact in buckle
Outer rear seat belts3ZD3-point seat belts, outer rear with US label
Center rear seat belts3C83-point seat belt, center rear with US label
seat coversN2ESeat trim covers in fabric
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A3seat heating for front seats separat controlable
Safety head restraint system3K0w/o safety head restraint system
Side lights7R4Side marker lamps and turn signal repeaters (turn signals with white lens)
Start-stop system/regenerative braking7L3Without start/stop system without regenerative braking
Horns8Y1Two-tone horn
Control number (no PR family)S2SControl (in-plant)
Control number (no PR family)SA0Model update, week 45
Side and rear windows4KCSide and rear windows in heat-insulating glass
power outlet7B212 volt socket in luggage compartment
Bumper2JGbumper in color of vehicle
Rear stabilizer0BFRear stabilizer
Front stabilizer0AEFront stabilizer
Drawers under front seatsQN0Without drawers under front seats
Heavy-duty/sports version2UCSports version
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N4Windshield wiper intermittent control with potentiometer (four speeds)
Special approval measures3M0Without special measures
Nameplate set0NHNameplate set "GTI"
Mass damper for steering wheels1Q0steering wheel without balance weight
Door and lid locking system4K0Central locking w/ radio remote control and interior controls
Type approval countries/countries with special requirementsB38Legal requirements California
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAwithout partition
Door and side trim panels4AFDoor and side trim panel in foam film and woven fabric
doors0A12 doors
TV reception/digital radio receptionQU4Satellite radio reception NAR integrated in device
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EBwithout identification plate
Delivery equipment2A8Delivery equipment, water border
First aid kit / warning triangle1T0Without first-aid material, without warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Telephone / telematics9W2Preparation for telephone
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG0without service interval extension
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W1Washer fluid level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Additional body panels, side6EAWithout additional side body covers (stone guard)
Additional child seat anchors3B8Child seat anchors as per Australian requirements and child seat system ISOFIX
auxiliary heater9M0Without auxiliary heater/fuel-fired parking heater
x
